GTM Performance Engineering Stage 1 Turn key Supercharger kit In house Install
Here is the last pics of the final phase for the install, shumby is a on the way home already. will be posting up the dyno results shortly
Sam
Sam
Spoke to shumby this evening, He made it safe and sound, this crazy **** drove 2300 miles straight home .Here is the final pics of the project with the dyno results, also i'm including some generic pics of a the Camp II HKs system, shumby had us install every sensors available for system(fuel, oil temp,oil press,boost, egt )plus all the info we get from the can bus .
Here is the final results with 6 psi @ 91 octane
Any reason for 6 psi? I recall you couldnt get up to pressure due to the headers, but I thought he put the stock headers back on, so with the stockies, you should be able to get 8 psi, no?
Its still pretty good numbers for 6 psi boost, just curious as to why 6 over 8?
