09 G37 Won't shift from D to DS
Old Apr 24, 2010 | 01:55 PM
E-Man's Avatar
E-Man
This happened on three occasions before dealer could diagnose and repair. Intermittent failure of shift mechanism to engage manual mode. The first time it was also associated with an issue that caused the engine to lose power. They apparently fixed the engine/electronics problem but sure enough two months later the shift problem resurfaced. They kept car for two days and said they could not reporduce the issue. I drove for three more months before the problem resurfaced so I drove directly to the dealer without turning off the engine. They finally diagnosed DTC P1815 which is failure of the manual mode switch. Since the swith is intergrated with the shift assembly, they had to completely replace the shifter assembly but I think they finally got it right. Soooooooo glad it was still under warranty or it probably would have costed a load. If you have this problem, you might tell your dealer to check that switch.
Old Apr 24, 2010 | 02:04 PM
TheLocNar's Avatar
TheLocNar
Nice. Sounds like you lucked out being able to go straight to the dealer at the tight moment. Was the CEL actually showing on the dash?
Old Apr 24, 2010 | 02:09 PM
E-Man's Avatar
E-Man
There was no clue on the dash. The only way I knew was when I shifted to manual to downshift approaching a stop as I frequently do, the indicator was still showing "D" and of course the transmission was not responding as expected.
Old Apr 24, 2010 | 04:43 PM
G37Sam's Avatar
G37Sam
I have the same problem now, the dealer told me it's just a switch/AT sensor replacement issue and is no biggie. I'm going to have mine replaced next time I go a service, thanks for the update.
Old Apr 25, 2010 | 07:36 AM
Q8y_drifter's Avatar
Q8y_drifter
This is a common issue actually. I had it back in summer 09 for a while and never really was bothered to fix it and then went away after a few weeks. Been working fine for the past year or so.
Old Apr 25, 2010 | 11:54 AM
swordsman54's Avatar
swordsman54
Same thing happened to me, and they replaced my shifter assembly as well.
Old Apr 29, 2010 | 03:13 PM
Ahujadaddy's Avatar
Ahujadaddy
wow... this just happened to me as well. Search really is your friend =p
problem goes away after restarting the car but has been coming back more often now. hope the dealership doesn't give me BS about any mods like grounding wires... knowing my luck
Old Jun 5, 2010 | 04:34 AM
AussieV36's Avatar
AussieV36
Hey Guys, did a search & I think I have the same issue with my 5AT
While I can start the car & Ds will work for a short amount of time, while in DS it will switch back to D mode on it's own & I can no longer shift with the stick
Sam, how did you go with getting the sensor replaced? did you have to get the whole assembly replaced or just the switch/sensor?
any info is appreciated guys
Old Jun 5, 2010 | 10:37 AM
RISKY GUY's Avatar
RISKY GUY
it's the shifter.
go into the dealer(left the car running when I had the prob)
show them it won't go into ds.
btw mine would only act up when the car was warmed up.
they checked once before and the car was ice cold, tech came back with can not duplicate.
next time I show up,car running and that same tech he felt like a moron.
he aplogized, and promptly replaced the shifter.
that was like a year or so ago. No problem since.
Old Jun 5, 2010 | 01:58 PM
SkyMG37x's Avatar
SkyMG37x
I'm surprised it took that long to diagnose. If you have enable a manual switch (i.e. move shift lever to DS) and nothing happens, the first place to look is.... the switch.
Old Jun 6, 2010 | 04:16 AM
AussieV36's Avatar
AussieV36
thanks guys,
unfortunately they don't sell this car via the dealer network in Australia, I have a grey imported jdm model, so I have to specially order stuff in from them (always a p.i.t.a unless I have part numbers or hopefully they use the same parts from the 350/370z auto trans.
at least I know what the issue is now
Old Oct 26, 2011 | 05:09 PM
aj5445's Avatar
aj5445
I'm having this problem. I installed paddles to my g37x by myself. Will my dealer give me a hassle regarding my warranty? I'd like to think not.
Old Oct 27, 2011 | 12:36 PM
DocJohn's Avatar
DocJohn
G-DOG
I bet your dealership doesn't even realize that your paddle shifters were not factory installed, much less give you any hassle about them.
Old Nov 10, 2011 | 12:47 PM
aj5445's Avatar
aj5445
Thanks.. you were right, they had no idea.
Old Nov 30, 2011 | 10:00 PM
LeeMichael's Avatar
LeeMichael
bump
08s coupe Hey im running into this problem been to the dealership twice already and they cant figure it out, After Replacing the switch have you guys run into the problem again?
