1st & 3rd Gear???
Old Apr 15, 2010 | 08:45 AM
911turbo's Avatar
911turbo
1st & 3rd Gear???
Hey everyone,
I was just wondering cause my 1st and 3rd gear kinda feel weird when I push the shifter into each of those gears.
Whenever im at a stop and put the shifter in 1st sometimes it will kinda go halfway and kinda pause like something is blocking itish but it will go all the way. And if I take it out of gear and then put it back it in, it will engage smoothly.
When I shift to 3rd gear some of the throws feel shorter and some of them feel longer in 3rd gear???
Maybe it might be me or is the clutch / synchros / tranny messed up?
Old Apr 15, 2010 | 04:17 PM
ucla bruin's Avatar
ucla bruin
My 1st is hard to get into too sometimes, but only when it's cold. Does the symptom go away after the car warms up?
__________________
Old Apr 15, 2010 | 04:25 PM
Mike's Avatar
Mike
Originally Posted by 911turbo
Hey everyone,
Try this. After you go into first, go back into neutral. But, instead of going back into first, let out on the cluch, and then step back on it, and go back into first. Do you still feel the resistance? If you do, that is your 1st gear synchro.
Another test.
Step on the clutch, but instead of going into 1st gear right away, wait ~5-10 seconds, and then go into first. Do you still feel the resistance?
Old Apr 19, 2010 | 11:36 PM
911turbo's Avatar
911turbo
There is that resistance when i engage the gear then move it back out and then re enage the same gear for 1st. Mike
Old Apr 20, 2010 | 12:09 AM
TomieG's Avatar
TomieG
I also feel this only when going into 3rd though. Feels like metal on metal contact.
Old Apr 20, 2010 | 08:33 AM
911turbo's Avatar
911turbo
Does infiniti replace / fix this under warranty or?? how would i go about getting it fixed under warranty?
Old Apr 20, 2010 | 09:37 AM
STOOF's Avatar
STOOF
I have that same thing with 1st gear.
It feels like it doesnt go in all the way and not smooth, i put it in neutral and right back into 1st and it goes all the way in like butter.
Ill try to let off the clutch in between and see if i still get it.
Old Apr 20, 2010 | 10:43 PM
911turbo's Avatar
911turbo
my 3rd gear does this stuff too =(
Old Apr 20, 2010 | 11:15 PM
sunten1's Avatar
sunten1
For me it is just 1st. Sometimes it doesn't want to go in. So I have to back out in to neutral and then throw it in first and it engages.
Old Apr 22, 2010 | 03:47 PM
cruzmisl's Avatar
cruzmisl
It seems like if I push in the clutch and wait a millisecond longer to shift, it usually goes in like butter. Also, pushing the clutch further down helps (by also forcing you to wait slightly longer to shift). Taking the revs a little higher before shifting also seems to help.
2nd and third gear shifts have been much, much better. When you're not comfortable with the way something is working, try to adjust.
I think our transmission and funky clutch have a really high learning curve. This is my first MT so I'm still getting the hang of the whole thing. I've felt the same things...especially a hard 2nd shift, but lately i've been trying to adjust my timing and it's actually resulted in the shifter just gliding into the right gear like I think it should.
37
Oct 17, 2020 11:12 AM
redlinernyc
Feb 29, 2016 11:06 PM
inspector94
Sep 8, 2015 12:57 PM
bingpwr
Sep 4, 2015 09:44 PM
