newbie question Alert: what are the engine differences between nismo 370Zvs G37?
Old Apr 7, 2010 | 01:01 AM
MKG37S's Avatar
MKG37S
are the engine codes the same? how the does nismo Z make 20 more hp? i looked at the engine specs. bore/stroke/compression is the same. is it all in the tuning? or does the Z have better exhaust and intake on it stock?
Old Apr 7, 2010 | 01:13 AM
TJHG37S's Avatar
TJHG37S
it's ECU tuning and b/c the exhaust pipes are shorter. same engine and intakes.
Old Apr 7, 2010 | 01:47 AM
myk1013's Avatar
myk1013
The brochure just states free flowing dual exhaust and a different H pipe configuration.
Sounds like the only difference is the exhaust system.
Old Apr 7, 2010 | 01:58 AM
TJHG37S's Avatar
TJHG37S
It's not, talk to anyone who knows Zs/Gs and they'll tell you the ECU tune is different.
Old Apr 7, 2010 | 09:33 AM
JonfromCB's Avatar
JonfromCB
The cars they are sitting in. Other than the plumbing....exhaust, minor air intake/box differences due to engine bay
differences and ECU, the "engines" are identical.
Old Apr 7, 2010 | 11:49 AM
cvt's Avatar
cvt
Just like TJHG37S stated...H-pipe config and ecu re-tune.
Old Apr 7, 2010 | 12:02 PM
MKG37S's Avatar
MKG37S
so you could easily get to that with the cobb tuning accessport?
Old Apr 7, 2010 | 12:05 PM
Mike's Avatar
Mike
No, you can't.
Old Apr 7, 2010 | 03:46 PM
Jamler's Avatar
Jamler
Originally Posted by Mike
No, you can't.
OK... So to get there what does it take?
- Intake
- Exhaust
- ECU Re-Tune?
Can't be much more than that right? If the engine is the same.
Old Apr 7, 2010 | 03:55 PM
Mike's Avatar
Mike
The problem is that the 'flashers' and 'tunes' out there are not able to adjust timing, lift, and duration. That is where the difference on the Nismo 370z really comes in.
Intake/exhaust/tune will not get you the Nismo's powerband; if you have the same peak power, you will actually have a superior powerband. The Nismo's strength is the (more) linear gain in power. You'll notice that the Nismo tends to keep gaining power as you rev, as opposed to the G37 which plateaus in power from roughly 6k to redline.
Old Apr 8, 2010 | 06:36 PM
vq37hr's Avatar
vq37hr
the stillen gen 3 intake has greatly helped my "plateau" issues. now, instead of leveling out, the power keeps climbing all the way to redline...
https://www.myg37.com/forums/intake-...fter-dyno.html
before the intake, you could def feel the power level off too early. i was pleasantly surprised with my results from intake alone.
35Sport
Feb 2, 2017 11:32 AM
Team_STILLEN
Future Models
13
Sep 5, 2016 03:13 PM
cellwoot
Aug 13, 2015 04:27 PM
reigle9
Aug 6, 2015 02:45 PM
