Dead in driveway.. parking lights "on", stalk in auto...
Old Mar 25, 2010 | 08:04 PM
YO-EL's Avatar
YO-EL
Wife came home a few hrs ago, just went out & said the car's parking lights are on & it won't start..
Checked the light stalk switch and its in Auto...
Went to charge it & after a few minutes the parking lights went off, and the battery is now charging..
Will arrange for a service appt..
Anyone have any ideas other than a short possibly?
Had the car 1 month, 800 miles..
Why would the parking (front & rear) be on with the switch in Auto?
The fog light switch is in the "on" position, but they only come on when the lights are on...
Any ideas or similar encounters?
Thanks.
Old Mar 26, 2010 | 11:13 AM
finagle69's Avatar
finagle69
I think that happens when the battery is low. Happened to me also in a parking lot. Had AAA jump me.
Old Mar 26, 2010 | 11:57 AM
YO-EL's Avatar
YO-EL
Dealer said maybe my wife pushed the button too fast & the car was in "accessory" mode, instead of full off...
We'll see.............
Old Mar 26, 2010 | 12:23 PM
ElLayG37s's Avatar
ElLayG37s
our batteries suck! Best is to replace, I've been stuck twice cuz of it.
Old Mar 27, 2010 | 10:14 AM
E-Man's Avatar
E-Man
I also notice that there's no atuo off for the headlights unless the auto function is on. In other words, if like me, you like to drive in the daytime with lights on (for safety) and forget to turn them off when you get out, they will stay on until the battery drains. That's crazy. Even cheapo cars have automatic lights out after a few minutes.
Old Mar 27, 2010 | 11:31 AM
x95stacey's Avatar
x95stacey
This is not true. They will shut off in 5 minutes. I do it all the time.
Old Mar 27, 2010 | 12:12 PM
SkyMG37x's Avatar
SkyMG37x
^+1. Also the warning chime comes on to tell you that the lights are on when you shut the car off.
But to the OP, there still seems to be a problem. If the stalk was on AUTO when the car was shut off then the parking lights should have turned off. The only way only the parking lights should ever remain on after the car is shut off is if you move the light switch to OFF then back to Parking, i.e. the auto shutoff doesn't work after the car is OFF and you turn the lights on. But since you said it was in AUTO that doesn't seem right.
Old Mar 27, 2010 | 12:19 PM
JonfromCB's Avatar
JonfromCB
Bingo, that's my bet. I learned this the hard way with my second
Infinity (first one with button/fob system) . The G does the same
thing. If you're in a hurry or sloppy about pushing the on/off button
and insuring your foot is on the brake hard enough to activate
the system, it's easy to assume you've turned all electircal off
and all you've done is turn the engine off......you walk away
and the battery discharges.
This isn't always the case, but alot of the "battery problems"
I've seen posted here are actually user error from folks who
don't take the time to put their foot on the brake and push
the button simultaneously long enough.
Old Mar 27, 2010 | 01:52 PM
ged1067's Avatar
ged1067
I don't get it: I never step on the brake when I shut the ignition and never had a problem. Where does it say that one must step on the brake?
GED
Old Mar 27, 2010 | 01:54 PM
ged1067's Avatar
ged1067
Pardon my bolds...I didn't mean to be screaming...
GED
Old Mar 27, 2010 | 03:18 PM
SindhiStyle's Avatar
SindhiStyle
I dont think it says in the manual that you need to step on the brake when turning off the car, only when turning it on...
Old Mar 27, 2010 | 06:32 PM
x95stacey's Avatar
x95stacey
You don't need to step on the brake to turn off the car. Just press the button once and everything turns off.
Amaadkhan2k
Oct 4, 2024 01:20 PM
User 122320
Sep 17, 2015 02:28 PM
TVPostSound
General Tech Questions
Sep 2, 2015 04:09 PM
