should i get an UpRev tune ?
Old Dec 26, 2010 | 09:46 PM
  #31
coolraz's Avatar
coolraz
Originally Posted by whiddles
thanks a bunch. when i data log which parameters should i use?
is there a Etune guide for dummies for me to follow?
Example how to drive while logging as well?
Go the Uprev website, then support section, there is a "Cipher User Guide" (cipher is for datalogging) and "Osiris User Guide" (osiris is for actually flashing your ECU). It has a set of parameters there as well as other instructions (basically, just read both!). You should do at least 2 good 0-60 runs (using the performance logging option) and then some regular cruising, that should give the Uprev guys enough info.
In case you need the parameters though:
**Verify your ECU is added to the AFR conversion. See Cipher user guide**
5.6.1.
A/F CORR-B1 (%)
5.6.2.
A/F CORR-B2 (%)
5.6.3.
AFR WB-B1 (AFR)
5.6.4.
AFR WB-B2 (AFR)
5.6.5.
ACCEL PED POS 1 (V-Accel)
5.6.6.
B-FUEL SCHDL (ms)
5.6.7.
CAL/LD VALUE (%)
5.6.8.
COOLANT TEMP (F)
5.6.9.
ENGINE RPM (rpm)
5.6.10.
IGN TIMING (BTDC)
5.6.11.
INJ PULSE-B1 (ms)
5.6.12.
INJ PULSE-B2 (ms)
5.6.13.
INTAKE AIR TMP (F)
5.6.14.
MAF GM/S (gm/s)
5.6.15.
MAS A/F -B1 (V)
5.6.16.
NB-O2 SEN 2-B1 (V)
5.6.17.
NB-O2 SEN 2-B2 (V)
5.6.18.
THROTTLE POS 1 (V-Throttle)
5.6.19.
URBINE REV (RPM) (Automatics only)
5.6.20.
VEHICLE SPEED (mph)
By the way, even without flashing the ecu, Cipher allows you to reset your ECU (the real way, not that pedal pressing thing that people talk about), so it unlearns your grandma driving style (or at least mine was apparently, b/c when I reset it, I could definitely tell the car was more responsive). Although I've been having some fun with the datalogging, I'm still waiting for Uprev to crack my ECU b/c apparently I have a very new one they haven't encountered yet.....hopefully it comes soon!
Old Dec 27, 2010 | 08:26 AM
  #32
RISKY GUY's Avatar
RISKY GUY
if they have around the same gains, how come I have not seen a tune via uprev crack 300whp.
yet using cobb my 1st dyno tune pulled 325whp on a dynojet.
Old Dec 27, 2010 | 11:21 AM
  #33
RedG37SNC's Avatar
RedG37SNC
Thanks I was asking cause I have a Cobb and just haven't used it.
Whiddles , go get it done, that little device can make your damn YEAR! Check Cobb site, they'll point you to know tuners in your area.
Cobb tune should run you between $350-$600, all depends on the tuner.. Mine was $450 and the best mod to date. See:https://www.myg37.com/forums/2931969-post1.html.
This looks to be your closest:
<TABLE border=0 cellSpacing=0 cellPadding=0><TBODY><TR><TD>MZM Motorsports
Subaru, Mitsubishi, MAZDASPEED, Nissan GT-R & Z and Infiniti G Pro Tuner AccessTUNER/Dealer</TD></TR><TR><TD colSpan=2>1904 W Howard Ln</TD></TR><TR><TD colSpan=2>Austin, TX 78728</TD></TR><TR><TD colSpan=2>(512) 837-6200 Phone
</TD></TR><TR><TD colSpan=2>www.mzmperformance.com</TD></TR></TBODY></TABLE>
For the OP, have you checked below for an Uprev tune:
Performance Motorsport East, Inc.
530 C Middle Country Rd.
Smithtown, NY 11787
theexperience.com
(631) 366-2152
Old Dec 27, 2010 | 11:35 AM
  #34
RedG37SNC's Avatar
RedG37SNC
I'm rather incline to believe it's the tuner..after all the tuning software is just a tool, it's the knowledge and experience using the tool that can make the difference. Then again Dyno's can be made to read what they like.. the only real reference I consider is the before and after comparison for gains.. and of course my Butt afterward which should confirm it..lol.
jfisher
Apr 25, 2017 01:22 PM
OneSickBlackG
Jan 6, 2016 08:49 AM
aj0415
MODDING 411
Dec 11, 2015 04:43 PM
parkern
Oct 5, 2015 12:12 PM
xmajd92
South
Sep 28, 2015 07:22 PM
