Braille Battery and effortless cranking
Old Feb 7, 2010 | 05:04 AM
shabbo's Avatar
shabbo
Just installed a Braille 3121 that I got on Amazon.com for $180
The battery itself feels about half the weight of the OEM and take less than half the space. Engine starts very easily now and the car weighs about 20lb lighter now!
The terminals line up perfectly and the installation needs minimal modifications.
The only modification needed is the addition of a some washers (comes with battery) under the brace-nuts to keep the nuts on the threaded portion of the clamping rod (Since the Braille is shorter than OEM Battery). Battery is significantly lighter so it does not take too much to hold it in place.
tip: you can change the Cabin filter while you're at it too
tip: you'll need to perform a window reset function after disconnecting battery
Old Feb 7, 2010 | 08:48 AM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
Its a great battery... I had one in my G except the Carbon Fiber verson... Throws out alot more power faster... Great Upgrade!
Old Feb 7, 2010 | 10:56 PM
GT35R's Avatar
GT35R
Does it crank better than a new and well charger regular battery?
Old Feb 7, 2010 | 11:50 PM
christian655321's Avatar
christian655321
yeah whats the purpose ? just lighter? or is it more powerful than the stock? Im all for space savings and weight reduction but wouldnt want to sacrifice cranking power or capacity.\
Braille Battery 21lb, 1380 pulse cranking amps, 550cca, 31amp/hr 2yr warranty - Right Side Positive Terminal
Old Feb 7, 2010 | 11:53 PM
VRG37S's Avatar
VRG37S
Nice.. Can you get away with the B2317R or it is not enough?
Old Feb 8, 2010 | 12:17 AM
christian655321
looked up replacement batteries for the car, and they have 640-650 CCA so this is acutally a downgrade but saves weight.
the M series replacments have 750CCA just so you know.. some people are reporting issues with their batteries dying on them , so i wouldnt go lower than stock if you run accessories.
Old Feb 9, 2010 | 02:20 AM
shabbo's Avatar
shabbo
I'd say it's the same...but the 20lb weight is saved from right above the passenger wheel is the main reason to go with this.
Old Feb 9, 2010 | 02:23 AM
shabbo's Avatar
shabbo
You want to have at least enough amperage as your fattest fuse
Old Feb 9, 2010 | 02:30 AM
shabbo's Avatar
shabbo
The battery dying is not related to the battery imo, but you're right that the Braille is a slight step down from OEM 582 CA (OEM) vs 550 CA (Braille 3121)
In CA that shouldn't make a huge difference at all, but it's a good quality battery with great weight savings directly above a wheel.
Old Feb 15, 2010 | 03:03 PM
myk1013's Avatar
myk1013
nice. Had to change my battery a month ago and it's PITA just to change the change it. It's not hard but having to remove all those plastic panels suck!
Old Apr 28, 2010 | 06:39 PM
shabbo's Avatar
shabbo
update:
Still running strong...cranks up nicely even after the car's standing for 2+ weeks
Old Apr 29, 2010 | 05:02 AM
Q8y_drifter's Avatar
Q8y_drifter
Thats great to hear, especially since my battery needs replacing soon (over 2 years now)
Old Mar 4, 2011 | 09:29 PM
ECain18's Avatar
ECain18
Does anyone know really what the lowest PCA/CA/CCA you should go on the g37? The stock battery has a CA of 580 (I think, can't really find any info on it), so Braille has a 17lb battery that has 641 CA and 475 CCA, would that be too low for a semi daily driver? I really have only been driving on weekends. Or would it be best just to get the 18lb or 21lb battery?
Old Mar 4, 2011 | 09:30 PM
ECain18's Avatar
ECain18
My battery is dead and looking for the lightest replacement that will still work great
Old Mar 6, 2011 | 02:16 AM
Mkai0's Avatar
Mkai0
I just bought an Optima Red Top for my 08 G35 Sedan because my OEM battery seemed to be dying on me. It works great and my car definately starts up better. It seemed lighter, not sure by how much, and it takes up less space. Might be something to consider.
