Help Fuel Issue
Old Jan 20, 2010 | 03:18 PM
Acftconsultant's Avatar
Acftconsultant
Fuel Issue
Guys. I need your input. I have had some problems with the car while fueling. The gas pump will shut off at 3/4 of tank like the tank is full and if you try to slow down the fueling it will spit back at you some times up to a quart. Have any of you had a similar incident? I have only had it happen to me once but the wife has had it happen a couple of times. Any ideas before I take back to the dealer. I never had this happen before on any of the cars and trucks I have owned.
Thanks for you input!
Old Jan 20, 2010 | 05:11 PM
ucla bruin's Avatar
ucla bruin
Try doing a search on the forum. There's been a few discussion on this or similar issue with refueling. I've had it cut off before it's full. I'd run it almost dry and was only allowed to refuel 14-15gal when the tank is 20 gal. Took it to the dealer and they found the resistance in my fuel sensor was bad. Replaced it and it hasn't happened since.
In any case, I think the dealership should be able to take care of it. Good luck.
__________________
Old Jan 20, 2010 | 07:11 PM
Acftconsultant
Thanks for the info. By the way the first thing I did was run a search but no hits! I will be calling the dealer in the am. This is why i love this site!
Old Jan 20, 2010 | 08:42 PM
ucla bruin's Avatar
ucla bruin
Sounds good.
Btw, nice picture.
__________________
Old Apr 23, 2010 | 06:49 PM
chasemyaccord's Avatar
chasemyaccord
My car is currently at the dealership getting inspected for this as well. Sometimes I get gas but my tank only shows anywhere from 3/4 to 7/8 full. Yesterday, I went into work and my fuel warning kicked in before I pulled in. After work, I started heading toward the gas station, and about a block before, I look at my gauge and I suddenly have 1/4 of a tank. So then I'm like wtf, so I go drive to my girlfriend's house about 5 miles away. I get there, and then my tank is on E.
Anyway, it looks like they'll be doing what they did to ucla bruin's car. Gonna enjoy my rental for the day while I have it. =)
Old Apr 26, 2010 | 12:17 AM
terrycs's Avatar
terrycs
Riverside Infiniti changed out my passenger side fuel level sensor under warranty for the same issue.
vamarris
Dec 9, 2018 11:10 AM
Manny735
Aug 14, 2017 09:25 AM
Awgd8
Sep 30, 2015 06:22 PM
Irishcurtis
Sep 30, 2015 11:39 AM
Slapshot1
Sep 27, 2015 08:40 AM
