GTM G37 SC Teaser Pix !!!
The boost is still low, this S/C kit should be at least 6psi and should make around 100 rwhp, and i wonder what the final product rwhp would be, and btw where's the BOV? does it have BOV or not?
It does but it recirculates back into the intake like a stock turbo car. Called a diverter valve. It should be quieter than a BOV. There's one only and it's connected between the intake tube and IC pipe. If you remove the tube connected between the diverter valve and intake tube, then technically you would have a BOV since the pressure is released into the atmosphere.
EDIT: Here you go
EDIT: Here you go
EDIT: Here you go
EDIT: Here you go
It's also called "Recirculating BOV", i would rather get one that's not made from plastic since the temperature here would get over 50c in summer, i found universal 1" recirculating BOV made by Perrin and TurboXS and some other brands, i wonder if there is an option for changing the recirculating BOV when buying this kit, or if they'll supply another type of BOV.
i don't know if that's a plastic valve or black anodized aluminum. Here's the one Jassem's 335i. They're made by Forge. the stock ones were plastic and caused boost leak with higher boost levels.
This BOV looks sweet, i'll get one when i get my GTM s/c for the sedan.
I don't know if it fits though, but I'm pretty sure you can find an aluminum recirc. valve that does. Or you can tell GTM to include one instead of the plastic one (assuming it's gonna be plastic)
Here is the latest pics and video
Sam
YouTube - GTM G37 SUPERCHARGER 8 PSI 468BHP/362 FT OF TORQUE 408 RWHP 315 RWTQ
Sam
Where is the filters ?? and btw that BOV is it plastic or other material?
Could it be replaced with another type?
PS, what's that little cooler on the front?
