Up-Rev Tuned: 2008 G37 6mt. (probably one of the first)
Old Nov 17, 2009 | 09:01 PM
oOmikeyboy's Avatar
oOmikeyboy
Alright guys, here we go.
I went to S&R Performance today to finally get my tune. The guys there were pretty cool and let me wander all over the place. I also think the tuner knew exactly what he was doing. We did like 4 runs total. The first one was 275whp, 308whp, 311whp, and then it went back to 302whp. I have 4 different maps, each having a different rev limit.
Map 1: full rev band (up to redline)
Map 2: max revs lowered to 3500
Map 3: 4000rpm
map 4: 4500rpm
For launch control: I go to whichever map i want to launch at, then specify after launching to revert back to map1, and it goes. i gotta try it out to see how it works.
Heres some pics
about to go on the dyno
too low, haha
strapped down
first run of 275, i didnt get a jpeg copy on my jump drive but i have a pic from my blackberry
the jpeg's that were copied to my jumpdrive of the runs:
302whp (final run)
311whp (best run)
A couple vids.
Overall i'm pretty satisfied with the gains. Now i'm not positive that i made a (275 > 311) gain because the 275 run ended at 6k rpm.
My blackberry did all the pictures/videos, so uh.. the quality isn't that good. Anyone know how the "Dynomite" dyno compares to something like a dynojet?
Old Nov 17, 2009 | 09:11 PM
Mike's Avatar
Mike
I'm not sure you made a gain either, since if you loko at around 5750 RPM on all your graphs, it looks like you're doing about 275.
If anything, it looks like the 302 was the baseline, and the 311 was the tuned dyno, as the 311 dyno is much smoother.
Congrats on the gains!
With the assumption that the 302 is your baseline, this dynomite reads a bit high. However, it does read that the "standard" correction factor is being used, not SAE. A stock G37 dynos around 275-280whp on a dynojet. As different dynos can't really be compared, just focus on your % gains
Old Nov 17, 2009 | 09:18 PM
oOmikeyboy's Avatar
oOmikeyboy
Yeah, i think we didn't get a good baseline that i could compare off of. Probably should have run the car before connecting any OBD ports, but i don't believe we did.
Old Nov 18, 2009 | 02:02 AM
G37Sam's Avatar
G37Sam
You're saying you didn't get a baseline dyno?
Your AF numbers in the first graph are scary btw
Old Nov 18, 2009 | 02:16 AM
G37Rider92649's Avatar
G37Rider92649
^ you should've seen my cobb ap and when I did my dyno run, shiet was like someone having a heart attack with a monitor attached on them, it was going up and down like a pointy mountain hahaha
O.P Congrats!!! Nice gains! Enjoy!!
Hrrm I wonder if you got test pipes and re-tuned you will see more gains, Mike chim in?
Old Nov 18, 2009 | 02:22 AM
Mike's Avatar
Mike
Not really anything I can say without a baseline...
The 311 is the "best" run and the 302 is the "final" run =X
10 hp variance is within the variance range of the dyno... so no way to tell what his gains actually were, if any.
Old Nov 18, 2009 | 11:18 AM
oOmikeyboy's Avatar
oOmikeyboy
^ Yep, thats exactly what i was thinking. All they gave me on the jump drive was a final run and a best run.
Old Nov 18, 2009 | 12:16 PM
Mike's Avatar
Mike
Can you stop by and ask for the first pull before tuning? Every shop I know of here in CA records every single pull done on their dynos.
Old Nov 18, 2009 | 12:39 PM
christian655321's Avatar
christian655321
launch control...... i wouldnt have thought of that - nice.
Old Nov 18, 2009 | 01:32 PM
oOmikeyboy's Avatar
oOmikeyboy
Its in Tampa. about a hour and 45min drive from where i am. I can give them a call and see if they can email it to me. I was standing by the car the entire time, and the 275 was the very first run, and the laptop was already connected to the ecu.
Old Nov 18, 2009 | 01:33 PM
Kidcane's Avatar
Kidcane
Florida G Club
Mikey, did they move their dyno over to the other building?
Also, not sure if makes a big difference but I think they dyno in 4th and I think our 1:1 gear is actually 5th. Anyone?
Old Nov 18, 2009 | 01:34 PM
oOmikeyboy's Avatar
oOmikeyboy
Yes i did notice that he shifted to 4th for the pulls. They relocated to the building next door, and yeah the dyno was moved also.
I was going to say something, but i figured he knew what he was doing. Is there a difference?
Old Nov 18, 2009 | 01:37 PM
Gamedog's Avatar
Gamedog
Sam Rothstein
Nah it don't really make a difference.
As long as all the pulls were all done in the same gear you're straight.
Old Nov 18, 2009 | 01:38 PM
Gamedog's Avatar
Gamedog
Sam Rothstein
Oh and good stuff Mikey
Old Nov 18, 2009 | 01:44 PM
Mike's Avatar
Mike
Gear doesn't matter as long as the ratio is properly input into the dyno.
