engine knocking
engine knocking
08 g37, my car always has engine knocking (the motor is hot and ususally happened when the car is stopping). i went to two different infiniti dealers, one dealer they told me that is motor oil problem ( changed the oil ), still same problem, the other dealer told me they cant find out the problem, can some one help me out, thanks
my car had this problem since 3000 miles.
keep pushing them to fix the problem... if they can't find the problem call the Infiniti customer hotline, report your problem and demand a new engine or car. If they make attempts to fix the problem and it doesn't work then your car may be lemon.
You might wanna search took me two seconds to find this
https://www.myg37.com/forums/engine-...when-idle.html
LMAO!! Funny Sol!!
OP read through this thread:
https://www.myg37.com/forums/tsb-tec...-actuator.html
You'll find some useful info.
I jacked this vid from youtube. Is this what you hear?
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/UGzmlGXLzBs&hl=en&fs=1&color1=0x3a3a3a&color2=0x99 9999"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/UGzmlGXLzBs&hl=en&fs=1&color1=0x3a3a3a&color2=0x99 9999" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
I have this same issue, I think a lot of people do too. As I'm driving the car for a while and come to a stop it makes that knocking noise. The TSB did originally fix it, but as soon as I switched from ester oil to full synthetic the noise came back. I'm not paying $125 per oil change to not hear the knock, so as long as it isn't doing any damage then we're good.
Most of the fix is coming from the oil, not the ECU reflash.
