G37 Transmission Issues with 4th -> 3rd Downshift
I finally had the time to bring the car in to Hoffman Estates Infiniti for an unrelated matter (rail dust on my rear emblem, had it replaced) and had an opportunity to speak to the service manager. When I initially talked to him a few weeks ago his impression was that the TSB had a negative effect on the performance of the car which swayed me to hold off on the TSB. Now that he’s had some time behind the wheel, he did notice that it in fact did improve the car’s overall performance as well as increased his MPG by a few gallons. He convinced me to give it a shot.
Although this did not fix the ‘Flare’ issue (knew that it would not), it did make a dramatic difference in how the car drives. There was no change in overall acceleration, but it did effect gear changes. It feels like the car’s up shift is, as someone mentioned before, more precisely. Instead of staying in the current gear a hair longer than it should it immediately shifts to the next gear. The car is now coasting with very little noticeable engine braking.
Overall, I am incredibly please with the update. It surprised me that a simple update could have such an incredible impact on how the transmission reacts. It really does feel like a completely different car.
Another surprise was how quickly the dealership was able to apply the update. Given I was only schedule to have the emblem replaced, they were also able to do the update and have me back on the road in less than 45 min! I was impressed.
I got a similar response when I went to the dealer this morning. They were told on the TSB that the update only applies to G37 Sport Sedan/Coupe, and since ours was a non-sport version, nor was the sports package added, they just told us there was nothing they could do. The technician explained that the parts number was different on the component that required the update. Has anyone else with a non-sport packaged or G37s sedan been able to successfully get the update besides him? Thanks.
My main problem was always right dead set at 20mph mark. Cruise at anything over 20 mph, lift foot off gas, and right when speed drops to 20 I had that huge jerky downshift. After the TSB, problem is GONE! I am a much happier owner. This downshift problem was a major thorn in my side. It is so much better now. It's like I have a new car again. I was driving around in an industrial area near my house for a while just to make sure I wasn't dreaming. Could not duplicate the problem any more. Thank you Infiniti!
Ah, sorry for the confusion. I did not go to the same dealer as mentioned. I went to Southwest Infiniti in Houston, TX. I still haven't gotten it resolved due to a busy week, but I intend on following up with the dealership to see if theres any additional development.
Yes, I noticed the flare issue baaaad when driving around tonight on some backroads - stomp on it from a roll, and the engine first does a throttle lag, then the revs jump but the car doesn't move, and then finally the car decides to get motivated - I also had a number of vdc and then some red one right above the DIC, but too quick to see what it was. Don't what that was all about, but the drive was very dissapointing. Right now, my transmission sucks. Does this TSB/TCM reflash address all these issues?
OK, that's completely different than the flare that most are experiencing. If the check AT light is coming on then bring it to the dealer, you may have more problems than a software issue.
Anyone with a 7AT should be able to get the TSB applied. I suggest making an appointment. Tell them your car is downshifting hard and ask them if they know about the TSB. That gives them a chance to look it up if they do not know about it.
They finally posted the complete TSB on one of the other Inifiniti info websites. Here's a copy:
http://home.comcast.net/~magredc5/G37/ITB09-032.pdf
Note Table A on the 3rd page - it lists the current TCM firmware part number based on the configuration (coupe/sedan/RWD/AWD).
