G37 Transmission Issues with 4th -> 3rd Downshift
Old Oct 21, 2009 | 09:12 PM
  #226
bikecop136's Avatar
bikecop136
Originally Posted by G37beijing
SILVER37: Could you please share new the TCU firmware version with us? It's likely printed on your service receipt. Thanks in advance.
Yes please do...... This downshift stuff is pretty ruff on mine too. Would like to do something.
Old Oct 22, 2009 | 06:55 AM
  #227
Silver37's Avatar
Silver37
Here's what the ticket says..."Completed ITB09-032. Reprogrammed ECU and TCU."
This appears to be the same ITB posted on the forum.
Old Oct 23, 2009 | 10:17 AM
  #228
fillup's Avatar
fillup
Does this happen to everyone in regular D mode too, or just DS/M? I can feel the rough downshift in DS/M but not D. It doesn't bother me much enough to go get it reflashed.
Old Oct 23, 2009 | 08:33 PM
  #229
Silver37's Avatar
Silver37
To look at this upgrade as a simple fix for the 4-3 downshift is being short sighted. The upgrade improves the syncing of the engine and transmission in many ranges and really increases the overall driveability. I would have done it a long time ago if I had known it would have made this much of a difference.
Old Oct 24, 2009 | 05:20 AM
  #230
bikecop136's Avatar
bikecop136
Thanks Silver. Going to get it done next week......
Old Oct 24, 2009 | 04:27 PM
  #231
Mike S.'s Avatar
Mike S.
I've had mine done and it makes the car much nicer to drive...slowing down that is.
That said...the 7AT is still not perfect. I'm sure it could be....but it needs more software. I get this rpm just as it upshifts after the car is restarted in a warm start situation...searh "flare" around here.
Also I have an occasional rough 3-2 downshift that happens at about 800rpm...almost like its holding on to 3rd TOO long...then kind jerks/bumps into 2nd. The most frustrating part...this stuff isn't all the time.
Don't be me wrong though...the 7AT is still a good unit. I mean....the rev match downshifts are usually damn near perfect. Also, it has a dual personality...soft at 1/4 throttle and then cracks off nice firm positive shifts at 1/2 throttle or greater. Combine that with a super short 1st and 2nd gear and this car (with AWD) leaves the line with authority!
Old Oct 24, 2009 | 09:18 PM
  #232
Silver37's Avatar
Silver37
I agree. The upgrade seems to really help mine make better use of 1st and 2nd gears on the upshift. In the past, I'd really have to get on the throttle to accelerate quickly in those gears, now it seems to accelerate much better in those gears with little effort. Before the upgrade, I used the paddle shifters frequently to tweak the shifting. I haven't even touched them since I had the upgrade done, so it seems tuned pretty well.
While not perfect, we have to remember that all the recent reviews of the car rave about the 7 speed auto, so it must compare favorably to others that are out there.
Old Oct 27, 2009 | 05:52 PM
  #233
irondog168's Avatar
irondog168
I got a 09 g37 journey, does any one have problem on downshift with journey ?
Old Oct 27, 2009 | 06:37 PM
  #234
kushBLAZER84's Avatar
kushBLAZER84
I'm in the same situation as you. I haven't noticed anything from driving in D but when I drive in DS that's where I expirience the rough downshifts and sudden RPM surges while braking for stop light/sign, only happens for a second or two then its all OK again. I'm still undecided if I want to get this TSB performed. What would you guys suggest?
Old Oct 27, 2009 | 11:01 PM
  #235
hadokenuh's Avatar
hadokenuh
If you are not bothered by the downshift in D, then I think you shouldn't have it done. DS is supposed to give you more "sport" feel so rough downshifts are somewhat expected.
"Don't fix it if it ain't broke"
Old Oct 28, 2009 | 08:35 AM
  #236
Radius's Avatar
Radius
Had the reflash done months ago and it makes no changes to DS mode, only D.
Old Oct 29, 2009 | 01:05 PM
  #237
slickd8's Avatar
slickd8
My new G37 journey probably already has the fix since I don't feel much on downshifts at low speed. The loaner car I used yesterday gave me headache when driving around parking lot. So I can tell the difference is big.
Old Oct 30, 2009 | 02:10 AM
  #238
JayDeePee's Avatar
JayDeePee
I am curious as to what is the build date of your G37? My G37's build date is 07/09. I just got the car 3 weeks ago with 9 miles on the odometer. I am wondering if the Transmission was flashed with the new software. I haven't noticed the downshift problem, but it does seem like at 30 to 40 mph the transmission searches between 3rd and 4th gear. Should I just take it to the dealership and have them look at it?
Old Oct 30, 2009 | 05:12 AM
  #239
Silver37's Avatar
Silver37
You most likely already have the fix. You'd definitely notice a hard downshift at 22-23 mph when driving normally - it used to throw my head forward between that and the engine braking until I learned how to anticipate it and compensate with very careful braking. If you typically brake hard, you might not notice there was anything out of the ordinary.
Old Oct 30, 2009 | 02:39 PM
  #240
JayDeePee's Avatar
JayDeePee
I tend to brake hard. I did notice a downshift jerk when I released the gas pedal today and cruising 23-28 mph. I think I am going to take it to the dealer anyways and have them check to make sure! I might not notice it too much since my other car has a manual transmission and I drive it hard.
