Grounding Kit question
Old Jun 26, 2009 | 11:30 PM
SkyMG37x's Avatar
SkyMG37x
Originally Posted by RedG37SNC
The grounding kits work to improve grounding of chassis ground to negative. The stock design already includes a wire from the negative terminal to chassis, these are just bigger wires with less inductive reactance along with direct connections versus going through already connected parts of the car.
I understand the intent, but from what I've seen the kit's wires are connected to the battery (-) terminal clamp, however the battery (-) is connected to the current sensor which in turn is connected to the chassis ground as per this diagram. Are the kit wires connected to the output of the current sensor? If not, I see this as a problem.
Old Jun 27, 2009 | 02:05 AM
RedG37SNC's Avatar
RedG37SNC
Interesting, never saw anything on the 12 Gauge wire that went to chassis ground but then wasn't looking for anything either. Will have to take a closer look and see where they put it.
Old Jun 27, 2009 | 09:25 PM
The current sensor is there on the OEM battery/chassis ground wire (at least on my car). I haven't haven't had any problems personally in over a year with my grounding kit installed, nor have I had any problems reported to me by any customer in that time. Neither my kits (nor any others that I'm aware of) are connected to the output of the current sensor. I wonder how cars worked before these sensors existed?
If you see it as a problem, I'd avoid grounding kits, at least the ones that don't include a current sensor.
Old Jun 28, 2009 | 01:04 PM
RedG37SNC's Avatar
RedG37SNC
You know what's really wierd here from some of the reading I've done is this circuit works to regulate the recharge system for the battery and while shorting it probably won't effect that to any great extent where it will have an effect is on fuel economy strangely enough. Apparently when the battery's in a good state it can lower the requirement on the generator which then results in better fuel economy. How much of an impact I have no idea but I'm going to remove the GK wire from the battery to the chassis cluster and keep the rest and see how things go.
Great catch btw Sky!, once again RTFM prevails!
Old Jun 28, 2009 | 04:20 PM
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
Interesting... keep us posted on your results.
I have yet to experience any issues with my setup but would love to see if better fuel economy results from Reds alteration of the BBGK.
Old Dec 8, 2009 | 02:43 AM
ozzypriest's Avatar
ozzypriest
I ran that search and I found this response, and it doesn't make any sense:
"The theory:
Installing a grounding kit is a safe and reliable way of creating a low resistance ground path for your car. The kit provides direct ground paths from battery negative to body, chassis, and specific engine components to give a noticeable improvement in electrical circulation."
Electrical circulation? What? What needs to circulate better? Does he mean to say 'resistance' ? Lowering resistance in the electrical paths in your car's electrical system system improves all these things? How? The ECU is a self-contained system, and increasing electron flow or reducing ohms away from or in to is going to affect what goes on inside the ECU exactly how? You're not controlling the electron flow inside the ECU unless you improve or alter the circuitry, ie, the circuit / motherboard.
"Reduced electrical “noise” can improve ECU signals and throttle response resulting in better performance and reduction in flat spots, better audio amp grounding and many other benefits associated with improved grounding."
Again, how? What noise? Resistance? The ECU needs to have its signal strength boosted? A grounding kit makes the instructions coming out of the ECU come out faster, and therefore throttle response is improved? I do not understand this reasoning. I want to know HOW reduced electrical 'noise' can improve throttle response, and what is meant by 'improve ECU signals'
There is no science or real explanation in this response. He jumps from point a to point z with no real indication as to what actually occurs. The only area where this explanation makes any sense is with the amp grounding comment. It was not helpful.
I am not saying it doesn't work, but I have to see an actual & factual explanation.
Old Dec 8, 2009 | 03:14 AM
G37Sam's Avatar
G37Sam
Hope you don't mind me moving your post here
Most new cars (including ours) come with a drive-by-wire mechanism. Meaning your gas pedal isn't mechanically hooked up to the throttle valve, but rather to a Throttle Position Sensor (TPS) which sends a signal to the ECU, the ECU goes through some tables and outputs a signal to the electronically actuated Throttle Valve, that's why I believe improving the circuitry improves response.
Same applies to the transmission since the ECU sends a signal to the transmission telling it to upshift/downshift
Old Dec 8, 2009 | 09:27 AM
SOLISIMO's Avatar
SOLISIMO
I think the feeling I felt was more mental then anything.
Old Dec 8, 2009 | 01:29 PM
HamstersG's Avatar
HamstersG
Blah, blah, blah with all the theories......I'm an electrical engineer and could write something technical up as well.....bottom line is it does not "hurt", most report noticable differences (including me) especially those with AT, and it looks good.
Old Dec 8, 2009 | 01:35 PM
ucla bruin's Avatar
ucla bruin
All the experts have spoken. Case closed.
Get it.
EDIT: to add to what ozzypriest and Sam were saying......what Sam is saying would be true if the grounding kit establishes a less resistant path for the ECU, but I don't think it does. Nor does it mess with any ECU internals. Not sure if there's benefit involving the ECU with grounding kit. Maybe if someone had a detailed diagram of the grounding from the factory.....
__________________
Old Dec 8, 2009 | 08:17 PM
RedG37SNC's Avatar
RedG37SNC
Grounding kits in general are a good thing but that doesn't change the fact that with this car and possibly others they have introduced a module to control battery recharge with the purpose being to improve fuel economy. If you bypass it you defeat that module and any benefits it would provide.
I've left the grounding kit but removed the bypass. Unfortunately I'm not one that drives with fuel economy in mind.. that's just not why I bought the car. But with how I drive there's been no real noticable difference not bypassing the module so for what's that's worth it doesn't seem to be worth worring about. I got about 19-20 before... I still get 19-20 now.
Old Dec 8, 2009 | 09:42 PM
SnoopDawg's Avatar
SnoopDawg
pocket protectors and slide rules aside fella's... Does anybody have actual data? Dynos or track times before and after installation? Now that could be convincing enough to make me part with my money!
Old Dec 8, 2009 | 09:59 PM
HamstersG's Avatar
HamstersG
Really? Track data or Dyno data on a grounding kit? Heck we argue on this forum all the time about track/dyno results when people change out big items. Kinda like asking what is the best oil? Nothing is going to prove it to you, so guess no one gets your money.
Old Dec 8, 2009 | 10:41 PM
  #29
SnoopDawg's Avatar
SnoopDawg
Hamster, folks are posting about "faster shifting", "improved throttle response" so I'm wondring if this is like, hey I just put synthetic in my Civic and it drives like a bat out of hell or is there some actual difference... My favorite are the posts about "inductive reactance", seriously the battery is a DC circuit and inductive reactance is a function of frequency, what's the highest frequency signal in the G? Couple hundred kHz, maybe a Meg? What's the difference in inductance per/foot? If you wanna buy your "G" some bling, go for it, don't try to use science to justify it Or spend the money on a new detail and you'll get better speed from the improved "laminar airflow".
I guess i should have used my <sarcasm> tags in the previous post...
Old Dec 8, 2009 | 10:54 PM
  #30
HamstersG's Avatar
HamstersG
Basically we are saying same thing....it ain't proveable. I think it helps and it is pretty [in lieu of sarcasm quotes].
Later as this horse is or or .
In closing:
