Shift knob not in park?
Old Jun 4, 2009 | 03:04 AM
g37mobbin's Avatar
g37mobbin
Shift **** not in park?
So today, i decided on working on getting my center console out and my radio console pieces off the manual says to put in Neutral before removing the shift **** and center console. So i do that. Everything went smooth until i put back the pieces together. then it tell me Park up shift...or more like shift to park but when i do it does not read it or sense it. Anyone experience problem or know how to fix it?
Old Jun 4, 2009 | 02:21 PM
g37mobbin's Avatar
g37mobbin
32 views and no one wants to help hmmm.... -_-....
Old Jun 4, 2009 | 02:54 PM
acura19's Avatar
acura19
did you disconnect a grounding wire?
Old Jun 4, 2009 | 03:26 PM
g37mobbin's Avatar
g37mobbin
no, just disconnected the lighter and wires to the center console
Old Jun 4, 2009 | 04:12 PM
oOmikeyboy's Avatar
oOmikeyboy
lol sorry. I clicked and wanted to help but i dont know about the AT's as i dont have one. So whats happening is basically you put it into park, but it doesn't register? What does it say ?
can pics help clear it up? For a second i thought the shift **** was mis-aligned from the park position because of the thread title.
Old Jun 4, 2009 | 04:22 PM
PeterUbers's Avatar
PeterUbers
I've taken apart my '06 Gx center console extensively and had your problem b/c i was off by two notches in the shift gate -- i had to re-adjust the shift gate UNDER the shift gate trim piece (adjusting the orange indicator -- which is actually a light now in the '07+ obviously) and re-feed the white stalk through the leather and chrome ring into the shift ****/switch...
i wonder if you're having the same issue? can you use the shift lock override to put the car into park and therefore reset it?
Old Jun 4, 2009 | 07:52 PM
terrycs's Avatar
terrycs
I thought there was a cable assembly going to the shifter gate. Did you reconnect it?
37
Oct 17, 2020 11:12 AM
vamarris
Dec 9, 2018 11:10 AM
ANMVQ
Dec 8, 2016 04:55 PM
Jonesmeister11
Sep 27, 2015 08:28 PM
Sep 25, 2015 01:38 PM
