turning traction control off
Old Apr 30, 2009 | 05:21 PM
smitty8930's Avatar
smitty8930
ok..i kno there is a button on the left of the steering wheel to turn off the vehicle dynamic control (vdc)....but is there another button somewhere or some setting to turn off the traction control system (tcs)...cus according to infinti's website they are 2 different things and do have different functions....very similar..but different...so i dono if there is a button or turning the vdc off automatically turns off both....?
Old Apr 30, 2009 | 05:30 PM
Scott at RA's Avatar
Scott at RA
I'm pretty sure turning off your VDC will turn off whatever you are looking for. It will give more control back to the driver without too much stability controll interference from the ECU. Your ABS will still be active with the VDC off, though.
Old Apr 30, 2009 | 05:35 PM
Mike's Avatar
Mike
Hitting the VDC button will disable both and you can do burnouts...
Old Apr 30, 2009 | 08:15 PM
Age's Avatar
Age
pushing the VDC button only turns off some of the traction... slip will still be on.. you cant fully turn it off which sucks
Old May 1, 2009 | 10:27 PM
Mike's Avatar
Mike
If you hit the brakes, then the car will assume you are trying to regain traction, and do what it needs to do to make the wheels stop spinning, regardless of if you have VDC on or off.
Old May 4, 2009 | 01:49 AM
w0ady's Avatar
w0ady
to completely turn it off, you have to pull the abs fuse.
Old May 4, 2009 | 09:21 AM
Jonneyboy48's Avatar
Jonneyboy48
how could i guess you knew that
Old May 4, 2009 | 11:01 AM
w0ady's Avatar
w0ady
lol heres sharif in treys old sedan showing us a burnout with the fuse pulled.
Old May 4, 2009 | 07:06 PM
tristan1334's Avatar
tristan1334
I'm assuming this only applies on 5AT or 7AT. I can do burn-outs on my 6MT when VDC is off. And the "slip" light does not blink at all.
Old May 4, 2009 | 08:35 PM
G37Sam's Avatar
G37Sam
He's on a wet surface.. he didn't need to take his fuse off. I'd love to see him do that on a dry road.
I took out the fuse and here's what happened
https://www.myg37.com/forums/audio-v...-abs-fuse.html
Old May 5, 2009 | 12:45 AM
w0ady's Avatar
w0ady
to do a burnout in the old g35, thats what you had to do. guess its not the same for the 37. ive done a couple in my 7at with just vdc off at stop lights lol.
vamarris
Dec 9, 2018 11:10 AM
timc00k
Feb 15, 2017 09:15 AM
parkern
Oct 1, 2015 10:15 PM
Landshark
Sep 29, 2015 11:20 PM
