Manual transmission problem!! Help
About a week ago i noticed that when i get the car up into the 5000 rpm or more area that there is almost like a rattle or vibration coming from what seems like the clutch area...if i drive below the 5k rpm's i dont notice anythin. its only wen i get on it...it doesnt happen every time i get on it...but id say 50/50...sometimes its fine...so i dono if the clutch isnt aligning properly..or if it is the throw-out bearing or wat...or if something in there is broken and rattling around or wat....any thoughts on what the problem is and why?
thats odd. How many miles do you have? It could be the bearing I guess but usually you hear the bearing at a neutral standstill point or when you depress the clutch and arent moving.
My best advice to you is make use of your warranty while you still have it.
Victory
Sep 28, 2015 10:49 PM
LVASJR
Sep 14, 2015 07:37 AM
