6MT problems????
Old Feb 11, 2009 | 07:12 PM
cholepuree's Avatar
cholepuree
how high are you guys reving at launch? usually im at 2k with the cluctch still partially engaged.... is this not a good thing?
Old Feb 11, 2009 | 09:31 PM
majin ssj eric's Avatar
majin ssj eric
I can tell you that it won't take 4k for sure...
Old Feb 11, 2009 | 10:13 PM
tristan1334's Avatar
tristan1334
Same thing happen to me at the track. Rev it up to 4k rpm and clutch went to the floor while rpm is bouncing on the limiter. I checked the fluid and it's on full level.
But I noticed that this only happened to me when weather is below 40'. If you pump the clutch while in neutral several times you will feel it get firmer. It ran fine after I pumped it at the staging area.
Old Feb 11, 2009 | 10:19 PM
VIP G's Avatar
VIP G
My gear shift has always been hard to get into gear, its not the new clutch/flywheel
Old Feb 11, 2009 | 10:38 PM
NIGHTLFEphantom's Avatar
NIGHTLFEphantom
Originally Posted by Formula1
Guys the 6MT that I test drove, the clutch pedal disengage very high. I remember in older cars the pedal could be adjusted, but I don't know much about the G. Is the clutch pedal adjustable or is it an specific setting?
I've been searching everywhere to find out how to adjust my clutch pedal... it's way to high for me... every time I let off the clutch my knee hits the steering wheel... even with the steering wheel all the way up. If anyone finds a solution let me know!!
Old Feb 11, 2009 | 10:41 PM
js3350z's Avatar
js3350z
Once I got used to the car which took about a week because I rarely drove it then, but now it is fine... Mine goes into gear VERY easy when rev matched, 1st to 2nd is a little twitchy if I am not paying attention but nothing to complain about....
On the other hand this is the only manual trans I have owned and I learned on big trucks... but when I drive other peoples cars sti's or mustangs most of the time they seem incredibly easy to drive
Stevolkz33
May 28, 2016 02:36 AM
butwhatuptho
Oct 4, 2015 07:51 PM
Jdragon1974
Sep 29, 2015 09:15 PM
Allboutcali
Sep 26, 2015 03:43 PM
