Starting off in 2nd gear?
Old Jan 16, 2009 | 02:42 PM
htownboy's Avatar
htownboy
Originally Posted by sbmwg37s
The first Gear is necessary for this car.
the only time uou can start with the second gear is when the car is already rolling.
Other than that, its a waste of gas, the clutch ,the engine and the transmission .
+1 But I always get out of 1st. quickly and into 2nd. (it actually does not harm the engine and trans, but it adds extra wear to the clutch for sure; if it was OK not to use 1st. it would not be there or we would just be driving 5 speeds)
Old Jan 16, 2009 | 02:50 PM
Mike's Avatar
Mike
You can start in 6th, but that's just abusing your clutch.
A 2nd gear star is very realistic, even 3rd is possible, but I wouldn't start in 3rd or anything higher.
ironhurts's Avatar
ironhurts
sorry to get off topic a bit but does anyone experience rough 1st to 2nd gear shifts? it seems like sometimes it will grind slightly when i shift from 1st to 2nd but the rest of the gears are fine...does this happen to anyone else?
Old Jan 16, 2009 | 03:56 PM
086mt's Avatar
086mt
I don't grind from first to second but I do notice that if I let off the clutch a little to fast I get a little bucking action. I don't get it when switching to any other gear, and I don't get when I let off the clutch slowly. But when I'm not being careful and I just let it out fast the car bucks, I guess it's because the clutch is real grabby.
Old Jan 16, 2009 | 03:59 PM
Mike's Avatar
Mike
Hydraulic assist clutches give the impression that it's rather light, but the clutch is actually VERY grabby.
The Vettes are a prime example of this
Old Jan 16, 2009 | 05:47 PM
086mt's Avatar
086mt
LOL I thinks that's an understatement. I guess it just takes a little getting use to.
Old Jan 16, 2009 | 06:01 PM
chasemyaccord's Avatar
chasemyaccord
What the heck? Mike? You have two screennames??
Old Jan 16, 2009 | 10:16 PM
Xcalibur's Avatar
Xcalibur
Yeah I get that noise too dude! Not a grind but it sounds like it. Dealer service said its normal after hell riding him around the block.
Old Jan 17, 2009 | 01:09 AM
oOmikeyboy's Avatar
oOmikeyboy
^ no grinding here, are you clutching in all the way to make the shift? I do however get a shuddering kind of noise, when i take off from 1st sometimes... like chatter or something. i also hate that.
Well anyways, i took off in 2nd a few times on the way home from work. worked surprisingly well.. smooth and no bucking in the take off. Almost stalled once or twice, letting out the clutch too fast though. Takes a bit of getting used to, but its definitely different! I like it.
Old Jan 17, 2009 | 05:16 PM
Mike's Avatar
Mike
Nope, just one
Old Jan 17, 2009 | 06:23 PM
tristan1334's Avatar
tristan1334
1st everytime, specially going over speed bump.
Old Jan 17, 2009 | 08:57 PM
jdm_inspire's Avatar
jdm_inspire
Originally Posted by gan78mao
^LOL i tried starting on 3rd, it works fine, but it sounds like the car is in pain LOL
Guilty of this as well. Sometimes I try and feather the gas to hit 1k rpm and lightly release the clutch and get that "I'm going to stall" sound.
With the tons of snow we're having in the Midwest (Michigan / southern Ontario), I still start in 1st at a complete stop and 2nd when I'm on a roll / slow speed.
Old Jan 18, 2009 | 05:28 AM
Gimquick26's Avatar
Gimquick26
i think the grinding is because our tran is not sychro...you can't shift so quickly coming off of or even past redline in first to go to second... that used to happen to me all the time with my first car and my second..my first car I had to get the tranny replaced bc it happened so many times from when I shifted to quickly from first to second and got the grinding happening. I was lucky it was covered under warranty
Old Jan 18, 2009 | 01:44 PM
  #29
oOmikeyboy's Avatar
oOmikeyboy
^ no, our transmissions have synchros.
Old Jan 21, 2009 | 04:53 AM
  #30
6chr0nic4's Avatar
6chr0nic4
ya when i first started driving it and wasnt so used to it i would let the clutch out too fast all the time and its really jerky... kinda lame
happens once in awhile now if im careless or not paying attention, kinda annoying especially if im driving someone they think i suck at shifting -_-
redlinernyc
Feb 29, 2016 11:06 PM
AMCDeac
General Tech Questions
Sep 19, 2015 05:25 AM
Rob Cooper
Sep 14, 2015 01:57 PM
inspector94
Sep 8, 2015 12:57 PM
