Official Cobb AccessPORT question, answer, and help thread
Old Dec 15, 2008 | 03:31 AM
  #91
kaos2774's Avatar
kaos2774
Originally Posted by kaos2774
I can't fined V1.03 on Cobbs web page are any G37 maps??
Got it.. I'm good
Old Dec 15, 2008 | 04:29 AM
  #92
G37Rider92649's Avatar
G37Rider92649
Originally Posted by AZg37
you could be doing some damage if your A/F ratio is off. I'd suggest using the live data monitoring with the cobb AP and see what your AF ratio is idle and under load.
my dongle is not working and will have to be sent into cobb to get it warrantied. I did manage to still get it loaded with someone else's dongle. I test drove it with stage 2 and it was fine, don't remember seeing the a/f myself under load, but idle was 14 steady.
Old Dec 23, 2008 | 10:40 PM
  #93
kevinyo's Avatar
kevinyo
AccessPort Issue
This thing scared the shiet outta me. I Saved my factory setting b4 upgrading to stage 2, ran with it for 1 week and uninstalled it back to Factory setting. The Uninstallation was successfull but my G wouldn't start, Battery was perfect, all I heard was this grinding, shaking from the either the engine or the transmission and the smell of Gasoline but somehow it wouldn't start, then I had tried the other route by putting stage 1 back in, now the car has no issue at all. Has anybody ever encountered this problem???
Old Dec 23, 2008 | 11:46 PM
  #94
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
nope ... never... i have loaded and unloaded mine about 10 times...
Old Dec 24, 2008 | 12:27 AM
  #95
G37Rider92649
did you load the the anti-theft map by accident? I think that's what it's suppose to do if you load that map. Why are you going back to your stock map if you have the mods for stage 2?
Old Dec 24, 2008 | 10:43 AM
  #96
matrix311's Avatar
matrix311
The v1.03 maps I mentioned are for a different car.
Old Dec 25, 2008 | 02:25 PM
  #97
whiddles's Avatar
whiddles
can someone help me get the 93 AT maps. this is all crazy for me.
Old Dec 26, 2008 | 08:09 PM
  #98
kevinyo's Avatar
kevinyo
Nah it was no accident, I loaded stage 2(Successful) and unintalled to check how my G was doing but it just wouldn't let my G cranked up. I'm running stage 1 now and don't know if it's gonna happen again if I uninstall Accessport outta my G.
Old Dec 26, 2008 | 08:20 PM
  #99
RedG37SNC's Avatar
RedG37SNC
The current preloaded Stage 1 & 2 maps are v1.00 and are for 91-93 octane.. there are not other maps to my knowledge on COBBs site.
Old Dec 27, 2008 | 10:42 PM
  #100
ironchef2008's Avatar
ironchef2008
My sole engine mod is the Stillen catback exhaust and now the Cobb AccessPort. That being said, Stage 2 is the preloaded map for me correct? Also, if I wanted to spring for a custom tune, can it be done via the datalogging on the Cobb or do I need to go back to the dyno?
Old Dec 28, 2008 | 12:14 AM
  #101
MaxToTheG37
Is anyone having a problem with 0-60 and 1/4 mile testing? Mine is not working right... it turns a 1/4 mile into like 4 miles... I ran a 1/4 mile today in like 3 minutes... same with the 0-60 ... I did it today and shut down at 70mph and was still 13% finsihed with the test... Ima try to update it to see if it works but just wanted to ask if anyone had any problems...
Old Dec 28, 2008 | 01:15 PM
  #102
chamelieon's Avatar
chamelieon
I didnt have any problems before i flashed the AP with the latest firmware with the datalogging, before that worked fine, now i havent tried it.
Old Dec 28, 2008 | 01:16 PM
  #103
chamelieon's Avatar
chamelieon
sounds like you need a witch doctor and some frog legs, your AP is possesed!
Old Dec 28, 2008 | 09:27 PM
  #104
Cuda760's Avatar
Cuda760
Max,
I had a similar issue the other day...I didn't have time to re-do it though. When I get some time this week, I'll see if I can't run some tests...
Old Dec 28, 2008 | 10:10 PM
  #105
MaxToTheG37
sweet...let me know....
