Limp Mode
Old Oct 23, 2008 | 08:07 PM
alunserjr's Avatar
alunserjr
The dealer can install Stillen parts and it doesn't void the Infiniti warranty. That would be the advantage over DIY.
Old Oct 23, 2008 | 10:06 PM
04STi208G37's Avatar
04STi208G37
Oil Cooler
That stock oil cooler is really what some call a heat exchanger. It is designed more to bring the oil temperature up quickly. It uses engine coolant to do that. It circulates the oil and coolant thru a heat exchanger constantly to keep them both at a relative same temperature. It works because the coolant heats up way faster than the oil. This helps the car by getting the oil temperature up to optimal operating temperature faster.
It can keep the oil cooler but only as cool as the coolant. An external oil to air cooler might lower the oil temperature 20 degrees. Oil works best at a high temperature but not over 240 I think. So like 220 is good but may 200 is better.
Old Oct 24, 2008 | 04:44 PM
Thrillhouse's Avatar
Thrillhouse
the stillen G35 cooler claims a 30-40 degree heat reduction, which would probably be plenty.
Old Oct 24, 2008 | 07:56 PM
alunserjr's Avatar
alunserjr
Is it applicable to the G37? I sent an email to Stillen requesting info on an oil cooler for the G37 - but haven't heard back yet.
Old Oct 31, 2008 | 02:19 AM
Lastchance's Avatar
Lastchance
Josh from Stillen said on another post that Stillen will have an oil cooler for our G's early 2009.
Old Oct 31, 2008 | 02:47 AM
dillyyo's Avatar
dillyyo
Limp mode sounds like a MAF sensor or the likes
ill12will8
Oct 26, 2015 10:09 PM
MrRiv
Sep 29, 2015 04:59 PM
pcwd
Sep 15, 2015 10:06 PM
drewfinity
Future Models
Sep 15, 2015 12:49 PM
