Faster as in you'll get to second quicker than you will now, because the MPH range in each gear has been decreased. But your not going any faster, if that makes any sense.
I meant the time it takes from the moment the shift is initiated until the shift is complete. for example: from the time that the paddle is tapped until the next gear is engaged.
FX35 with 7sp gained 1mpg in city and highway while the engine gains 28hp. FX50 with 7sp gained 1mpg in city and 3mpg in highway over FX45 while the engine gains 70hp. So the 7sp helps V8 in FX50 more even with more powerful engine.
They won't change the engine for 2009 G37 coupe. I'm hoping the 7sp will help gain about 2mpg. I'm guessing 19 in city and 26 in highway. That will put G37 over 335, IS350 and TL SH-AWD in terms of efficiency. What do you guys think?
It's possible........... 2mpg is probably the most it will gain... And that's fine with me,,,,,,, I'll take it!!!!!!
