About to do an Oil Change need info first!
Old Aug 16, 2008 | 02:56 PM
notalk's Avatar
notalk
Thanks.
Old Aug 17, 2008 | 09:45 PM
joeposter's Avatar
joeposter
Originally Posted by BiscuitWeasel
7,000 is way too late for the first oil change, the manual says to change every 3,750.
3,750 for severe conditions. 7,500 is fine for normal conditions.
Originally Posted by Retromoe
once it starts to get black, thats when i change it.
You can't tell when to change the oil by looking at the color.
http://www.nordicgroup.us/oil.htm#Th...k%20Oil%20Myth
Old Aug 18, 2008 | 07:24 AM
dentalstud's Avatar
dentalstud
20 Year Member
Originally Posted by xdram
what??? bmw said to do oil changes on my e46 every 15k miles but I did it every 10k and with 110k miles, 10 years later I never had engine issues. I'm pretty sure 7500 miles on the g is fine, that's what i'll be doing. I can't handle oil changes every 3k miles and I'm not about to take it anywhere for oil changes because I don't trust them.
You DO know that the reason BMW recommends 15K miles is because they do free maintenance for the first few years now, right? It's certainly not because their engines are so much tougher or their oil so much more effective. The fewer oil changes for free, the better. You are right that if you are not going to be keeping the car for much over 100K miles, you probably won't have a problem. That's what BMW is banking on by cheaping out on their "free" maintenance. The problem is that once the "free" period is over, the damage may be done, which means lots of engine repair bills that YOU will be footing. Brilliant strategy on their part.
I will say that I actually think the old 3000 mile standby is overkill. about 5K for normal driving is fine. But if you want warranty work done, you better follow their recommendations, and that means 3750.
Old Aug 18, 2008 | 02:53 PM
joeposter's Avatar
joeposter
Not sure why you would spend 40k for a car then try to save a few bucks on oil changes.
If there was any evidence that it would do any good I'd be all for it. But there's lots of evidence that it's useless.
How often do you think a cab should change their oil? Seems like 6k is fine. Under normal driving conditions you could easily go 10k - 15k so 7.5k is already conservative.
If you do any stop/go driving, which is just about everyone in a city, it's 3750 miles between oil changes.
It's not "any" stop/go driving, it's "primarily" stop/go driving. Which would likely include everyone living in a city but not the rest of us in suburbia.
Then again, I stop every time I go so maybe, maybe I should be on schedule 1.lol
Old Aug 18, 2008 | 04:00 PM
weave's Avatar
weave
That TSB is funny in the fact that EVERY dealer I ever worked at all use generic bulk oil brought in by big trucks.....pumps right out of the wall into a can, into your engine.
So, do not assume that your dealer is using that TSB oil unless you ask for it, and even then I would question it.
As for me, Mobil 1, 0W-40 FTW!!!
Old Aug 18, 2008 | 08:51 PM
vINCe_Inc's Avatar
vINCe_Inc
i change my oil frequently not for the life of the engine, but for the performance boost i get from a engine that feels more lively and smooth.
Old Aug 28, 2008 | 05:17 AM
shabbo's Avatar
shabbo
Originally Posted by koelzmod
We should try to get a group buy on K&N oil filters. If everyone ordered 10 maybe we could get a better price, but then again maybe there are only a few of us that don't trust anyone to do their oil changes. A friend of mine lost an engine do to some yoohoo at an oil change place years ago. So I've never considered not doing it myself.
I had the K&N performance gold, and the dealership said that that can void the warranty!! what a bunch of dimwitts working at these dealerships
wiseguys also overfilled the oil! that too before an oil consumption test.
Old Aug 28, 2008 | 10:37 PM
sup3rman's Avatar
sup3rman
Hey, you guys think if it's okay to use ow-50 oil? I got 10K on mine.
Old Aug 29, 2008 | 10:01 AM
notalk's Avatar
notalk
Not according to an oil company engineer friend of mine. I asked him if I could use 5W-40 synthetic in the G37. I live in Phoenix and wondered about a 30 weight in our summers. His short answer was "no". His long answer was that the internal clearances are sized for nothing greater than a 5W when cold and starting up and nothing greater than 30 when warmed up and hot.
Bottom line, for current modern engines, nothing higher than the recommended "cold" and "hot" recommendations. Lower, especially for the "cold" recommendation in strong winter climates, is okay. But, never higher.
P.S. I know a lot will post "I use 20-60 and haven't had a problem, so use what I use." I am only passing on what oil company engineers are saying for current engines.
Old Sep 14, 2008 | 08:32 AM
groinkick's Avatar
groinkick
goto advance auto parts.
buy 6 quarts of 5w-30 mobile one, ramps, an oil filter fram or whatever, i like fram cause of the grip, filter wrench, oil drain pan, funnel, 10mm socket, and i think 14mm wrench.
drive up on ramps, there is 4 bolts on the rear of the plastic panel, take those out with your 10mm socket, open your drain plug, drain, remove filter and replace. fill 5 quarts in and a splash from the 6th bottle.
Old Sep 16, 2008 | 03:41 PM
shabbo's Avatar
shabbo
Got back from the dealership yesterday on the 2000 mile oil consumption test. My G is about 1 quart low and they said it was normal.
The Manual says that engine will consume some oil between intervals, and the dealership said that it's normal to consume upto about 1.75 quarts between changes. Before they were saying that it should NOT be consuming oil!
Even Nissan seem to have been unclear on what oil to use and the switch to Ester blended oil is to address the evaporation issue aswell, since unlike German cars the G only has 5 quarts for a 3.7 liter HR engine!
Old Sep 16, 2008 | 05:39 PM
joeposter's Avatar
joeposter
Actually, the G37 has a total 6 quarts.
5-1/8 Drain and refill with oil filter change
4-7/8 Drain and refill without oil filter change
6 Dry engine (Overhaul)
Old Sep 19, 2008 | 02:36 PM
BroDaJin's Avatar
BroDaJin
the reason why BMW and Mercedes recommends oil change at 10k+ miles is because they use 8-9 quarts of oil. But if I was an owner of BMW or Merc. I would get my oil changed at 5k. recommended oil change intervals are all wrong. It all depends on how the car is driven. Just check your oil everytime you fill up the gas tank.
And to the OP. You should of done your first oil change at around 1500 miles.
It is critcal for a new engine to break in properly.
Old Sep 19, 2008 | 03:20 PM
  #29
BroDaJin's Avatar
BroDaJin
I know for a fact that BMW dealership must use Castro brands of oil when ever they are servicing car and Mercedes dealer must use Mobile1. I know because I get great prices buying them from the dealer through a whole sale account.
Old Sep 19, 2008 | 09:51 PM
  #30
joeposter's Avatar
joeposter
Yeah, they're too conservative. The only way to know for sure is doing an oil analysis but cars can usually go 10k - 15k between changes.
http://video.yahoo.com/watch/2928419/8382445
Rayramg37
Nov 18, 2015 09:06 AM
Victory
Sep 28, 2015 10:49 PM
sharmelan
17
Sep 14, 2015 03:18 PM
