Car not the same AFTER ECU TSB reflash :(
Old Jun 10, 2008 | 07:29 PM
Keng's Avatar
Keng
Oops! I meant 6 MT not an automatic. You knew what I meant!
No I don't, me so silly
Old Jun 10, 2008 | 08:06 PM
leeladisky's Avatar
leeladisky
Folks - I don't agree...many people, including me, have had the ECU reflashed and did not experience this issue afterward. However, that being said, my car just started exhibiting the same problem, 5k miles after reflash and 2k miles after installation of my FI exhaust/cat setup. Dealer tried to blame the FI exhaust as there were no codes thrown, and then they suggested I run the car to empty and switch fuel brands. The car sputters when revved in neutral/park and has VERY limited power until I hit 3k rpm. This started suddenly last night and no one can figure out what is going on....OP - Let us know what you find out but don't wait. The dealer told me to bring it in immediately upon description of the problem to avoid potential subsequent damage to other components...again, no solution and no direction from dealer.
Old Jun 10, 2008 | 08:36 PM
aero's Avatar
aero
Guys, I could be crazy, but I have a feeling a lot of the new auto G37s are having serious transmission issues. What happens when you drive in tiptronic? Try a spirited run as if it were manual, start out in 1st, gun it, shift before redline, continue up to 3rd. If you don't haul, it's probably an engine or ECU issue. If you do haul, it's probably a transmission issue. Almost sounds like the TCM on the valve body is stuck in failsafe mode (4th gear) for drive.
Old Jun 10, 2008 | 09:01 PM
Ahujadaddy's Avatar
Ahujadaddy
ohh wow, i thought this thread was gonna be about someone being sad after gettin the technosqaure ECU reflash.
*whhheeeewww*
Old Jun 10, 2008 | 09:25 PM
Pms1212's Avatar
Pms1212
Originally Posted by TomG37
Is this a problems on the all the 37's? 6MT too?
I drive the 6MT and have done the ecu reset and have had no problems. Mine seems faster
Old Jun 11, 2008 | 10:39 AM
leeladisky's Avatar
leeladisky
This is about the ECU reflash for 5AT's, not just a reset.
Old Jun 11, 2008 | 11:31 PM
Lastchance's Avatar
Lastchance
I'm confused by this thread. I have the auto and had it reflashed by TechnoSquare. I drive all day long in DS mode with tiptronic with no probs. What exactly is the concern...transmission probs or sluggish ride?? I just want to understand so I don't do anything damaging to the car. Runs strong right now.
Old Jun 12, 2008 | 12:59 AM
leeladisky's Avatar
leeladisky
This is about dealer/factory reflash for the TSB, not an aftermarket reflash...
L
Old Jun 12, 2008 | 01:09 AM
Skyline-LEXY's Avatar
Skyline-LEXY
How much different is it from stock reflash??
JY
Old Jun 13, 2008 | 01:56 AM
Lastchance's Avatar
Lastchance
Ohh, OK. Can you give me the rundown on what the TSB is and why some need it factory reflashed. By the way, the TechnoSquare reflash is great!! It unlocks the hidden power in your car.
Thanks
Old Jun 13, 2008 | 03:51 AM
Lastchance's Avatar
Lastchance
Woops, nevermind...I just saw the thread on the issue. I'm going to take my car in also to see if they will get rid of the surge.
Old Jun 13, 2008 | 08:36 PM
koelzmod's Avatar
koelzmod
how do you get the technosquare reflash and is it only neccessary when you do any modifing,or is it something you do on a stock system?
Old Jun 15, 2008 | 02:46 AM
Lastchance's Avatar
Lastchance
You can do it on a stock car. Cost was $550.00. when you add a bolt on part, you can go back to them and reflash again for 150.00. DeiselDoug has a good post on it.
Old Jun 22, 2008 | 12:46 PM
  #29
koelzmod's Avatar
koelzmod
In reference to the Technosquare reflash. Do you know if will improve performance on a stock system. Also, do you know how I can find someone in Florida that can do as good of a job as Technosquare. How do I find DeiselDoug's post? And final, as of to date what are the preferred type and brands of mods of most guys. Example Stillen headers? What brand test pipes or high flow cats? Borla or Fast Intentions exaust? Whose cold air intake? Sorry for all the ?'s. I'm not able to get on site as much as I'd like to. Trying to catch up on the latest stuff. Thanks.
Thedbarz
33
Feb 9, 2016 12:05 AM
BANNISTER
Dec 10, 2015 04:14 PM
SLEV3N
General Tech Questions
Oct 17, 2015 05:58 PM
350zrunnin12s
Aug 9, 2015 09:55 PM
delfinparis
Aug 8, 2015 06:09 PM
