ECU tune finally done!!
Old Apr 24, 2008 | 05:20 AM
  #76
NemesisG37's Avatar
NemesisG37
Originally Posted by bboysteele
NA is still really good and will last a lot longer than a FI. FI is better for power but has side effects! The motor that is..
If properly developed and professionally installed/tuned....The motor will last just as long with FI than without.
Old Apr 24, 2008 | 05:26 AM
  #77
fireboy's Avatar
fireboy
yeah i thought about doing all of that to but i said hell with it and went big and being one of the first deffinately hit some road bumps but they have fixed them selves... as far as tunning the ecu is so dam smart you cant really tune it much at all unless you have the technology to rewrite the computer or want to spend the 3-4000. on a full fcon system your not going to be able to tune this car the way it should be..... AAM is getting this program and the trained personel to be able to rewrite the computer..... i think that is alot better than putting in a full fcon system.... i dont know alot about it, i dont tune cars, but that is what i was told....hope this helps alittle
Old Apr 24, 2008 | 06:31 AM
  #78
todd92's Avatar
todd92
Originally Posted by Dieseldoug22
Now going purely off max HP it is as follows: And these are all Dyno Jet weighted numbers.
Stock ECU & Stock Air - 293 HP
Stock ECU & Fujita - 296 HP
Techno ECU & Stock air - 299 HP
Techno ECU & Fujita - 304 HP
Techno ECU, Fujita & HFC - 312 HP
ABOUT 21 HP GAIN
But the numbers are real misleading because they each peak at different RPM's and the gains in the mid-range are kind of different from the peaks. Like the Stock air box and the tuned ECU has a slight advantage in HP in the MID, until you hit 6900 RPM's them the Fujita and tuned ECU has more.
I don't see why you people are having a hard time interpreting these numbers. The tune gave 6-8 peak HP, and according to the poster boosted midrange HP and throttle response according to his seat of the pants. That's the best you can hope for from a tune on a modern NA car. Tuners can't get any peak HP out of NA BMW's anymore, just improve the midrange and throttle response. Sounds like Technosquare does a good job.
Old Apr 24, 2008 | 10:04 AM
  #79
Buddy Revell's Avatar
Buddy Revell
Thanks for being the first to do this, Doug! This answered a lot of questions. Another great contribution from you for the G37 community!
Old Apr 24, 2008 | 10:22 AM
  #80
willizm's Avatar
willizm
It shouldn't be too hard to recode, compile, and reflash the ECU. It just requires the right expertise to do it. As with any security in the digital age, if there is a will there is a way. Things may get more involved with newer cars, but it will be circumvented.
Old Apr 24, 2008 | 05:15 PM
  #81
Dieseldoug22's Avatar
Dieseldoug22
Thats really part of the problem... they can't just reflash the ECU. After they flashed it they had to put back a lot of the original programming. The ECU no longer only controls the engine. It is part of the computer system of the car. The ECU talks to ALL aspects of the car. And has memory of EVERY system on the car. According to Tadashi. So the best that they can do now is try and adjust the parameters to do what we want it to do. And yes there are always back doors. Just watch the MATRIX.
Old Apr 24, 2008 | 05:17 PM
  #82
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
I hear AAM has access to be able to rewrite the ECU... I hope this will yield gains that were looking for
Old Apr 24, 2008 | 05:18 PM
  #83
TerribleONE453's Avatar
TerribleONE453
cant wait to hear more abotu that... ^ i was hoping to be over 300WHP without a tune... on the right dyno of course
Old Apr 24, 2008 | 06:02 PM
  #84
The1andOnly's Avatar
The1andOnly
Damn, Nissan's ECUs are getting more & more difficult to put mods with. And now it seems that it getting harder to make changes to.
Old Apr 24, 2008 | 06:31 PM
  #85
MrRat's Avatar
MrRat
Were the dyno's done hood up or hood down?
I guess someone should monitor the IAT sensor while driving and compare the readings stock vs. an aftermarket "short" intake.
I would guess that midrange response, throttle response, and consistency would be better after tuning as well as getting about 10 peak HP and a fatter torque curve. I find that sometimes I'll get on it and it goes pretty well, other times it seems to be missing 20 HP.
I'd like to see 1/4 mile runs/ trap speed differences between tuned/untuned. Seems like a good mod for $500.
Last thought is that California typically has 91 octane premium, I wonder what could be done with 93 octane mapping.
Old Apr 24, 2008 | 06:52 PM
  #86
Dieseldoug22
I am not sure... but my intakes are down in the bumper with the faux brake vents opened up. So I guess it doesnt really matter.
Old Apr 24, 2008 | 07:22 PM
  #87
Kidcane's Avatar
Kidcane
Florida G Club
On the right dyno that will be possible. I put down 277 bone stock in 4th gear. Put it in 5th and a couple bolt on's should put me right at 300.
  #88
Kidcane's Avatar
Kidcane
Florida G Club
Oh and this is great news. Thanks Doug.
Old Apr 28, 2008 | 07:39 PM
  #89
Chebosto's Avatar
Chebosto
Thumbs up
To all that may be interested, Technosquare just finished the Reflash for the G37Coupe MT Prototype car. The car came to us already with a prototype HKS Exhaust (which includes downpipe and mufflers), but stock cats, stock headers, and aftermarket intakes were installed.
Got some good strong numbers throughout the entire band, and the car now pulls all the way to the new Rev limit, which is 500 more than stock (although on the graph, it doesnt show it, but it is.) Things changed were Timing, A/F, throttle control, rev limiter raise and speed limiter removal.
TechnoSq is quite happy with the results on this prototype car, this was done using 91 California pump gas. 324.9 rwhp, 250.6 ft-lb torque....
93+ octane states could see a little more with more advanced timing...
If you have questions, please feel free to PM me (i'll try to check back often) or you can email me directly.. Chezee350 at Hotmail.com.
--Cheston
(i was the 2003 350z ECU beta tester for Technosquare)
Old Apr 28, 2008 | 07:47 PM
  #90
06mtg35's Avatar
06mtg35
Wow!!! How soon Before we could get our ecu Done?
