Clunking sound came back again after oil change.
Old Feb 26, 2008 | 06:48 PM
patmsb1's Avatar
patmsb1
Well, I'm experancing the same problem again when the car is at a idle for about 5 - 15 minutes. This time they're are going to replace the actuator for the WVEL technolgy. I happen to be around the dealership when it started to do it again. I met the local Infiniti rep. today and he seemed to really not care about my problem. He said that it makes a little sound over the engine noise. I'm glad that he's not a tech. because I would be really alarmed about having someone with that attitude working on my new $40,000 car. The sound is not faint and has a nasty knocking sound to it. I'll keep you informed about this problem.
Old Feb 27, 2008 | 12:03 AM
Orbie's Avatar
Orbie
I'm interested in the sound you're hearing, could you post a sound clip so the rest of us can hear what you're hearing?
Old Feb 27, 2008 | 02:36 AM
TerribleONE453's Avatar
TerribleONE453
is your car a 6MT? and do you only get the sound when you release the clutch in neutral? if so i get the same noise... kinda sounds like s diesel as someone described it on the forums
Old Feb 27, 2008 | 10:27 AM
Trader_J's Avatar
Trader_J
Does your car make the sound when you first start it at all? I know this sound (and its not the mufflers as people will tell you). It's coming from the engine bay.
Old Feb 27, 2008 | 02:07 PM
TerribleONE453
Mine doesnt do it when i first start it... but if it is warmed up... The sound will be there when the clutch is out sitting in neutral. it is actually quite loud
Old Feb 27, 2008 | 04:36 PM
chilibowl's Avatar
chilibowl
This has nothing to do with the OP's post. What youre hearing is a throwout bearing, and you will find the same noise amongst all G's and Z's. The sound the OP is talking about is an engine-related noise. Two completely different things.
Old Feb 28, 2008 | 02:04 AM
patmsb1's Avatar
patmsb1
I've noticed the throw out bearing noise as well. The sound I'm talking about is coming from the engine bay and and it makes a nasty knocking sound. The car is at the dealership right now so I can't post a audio clip of it and if this doesn't fix the problem I'll defently post it so you can all hear it and see if your car makes this noise. Thank you!
Old Feb 28, 2008 | 04:26 PM
Arrowhead's Avatar
Arrowhead
Is this some kind of engine ticking issue same as BMW E90/E92?
Old Feb 28, 2008 | 05:38 PM
TerribleONE453
My friends 6MT G35 doesnt make the same sound..
TerribleONE453
You better be beating on that loaner
Broski28
Feb 26, 2016 12:26 PM
bikerjosh
Aug 19, 2015 11:26 PM
GODMODE
Aug 15, 2015 05:24 AM
SS2006
Aug 11, 2015 10:24 PM
