GAS-Regular or premium? and GUMOUT-good or bad?
Old Jan 21, 2008 | 11:08 PM
RedG37SNC's Avatar
RedG37SNC
It's interesting to note that lower grade gas is actually more volatile then the higher grade gas. That's the problem and why it causes pre-ignition aka knock. Newer cars do contain knock sensors that detect detonation and automatically retard the spark to compensate. The delay means maximum gas expansion occurs when the piston is farther along in its downstroke and thus there's more room in the cylinder head. This reduces peak cylinder pressure, eliminating knock but also giving you less power and poorer mileage.
Actually re-reading the manual I notice a fairly significant difference. For the G35's engine it's a "recommendation" to use 91. For the G37's Engine it's a "Use" 91, quiet different from a recommendation. It even goes so far as to state temporary use of sub 91 is ok but only mixed.
Old Jan 21, 2008 | 11:33 PM
NemesisG37's Avatar
NemesisG37
Originally Posted by 3des
Guys...The octane rating of these and any performance motor is driven by the compression ratio. If you fill with sub 91 octane fuel consistently you risk knocking. Knocking = engine damage. If you cannot afford premium fuel for this car then you cannot afford this car. Sorry.
This is true.
Old Jan 22, 2008 | 12:30 AM
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
Filling up with reg over super- you save a maxium of a whopping $4.00!
Save yourselves some trouble and just use the super. If you can't afford $4.00 per fil up then I would suggest something that runs on lower octane. Additionally any money that you may save will probably be offset by worst fuel economy. This engine has high compression and if you detonate fuel before you can burn it then you are using more fuel than you normally would unless you drive like a granny. Higher octane will burn more efficiently and cleaner in these cars.
I know folks who use lower octane to save money and then go out and buy an $8.00 bottle of "octane booster" to compensate. That makes no sense to me.
Old Jan 22, 2008 | 09:40 AM
Dominican_Capt's Avatar
Dominican_Capt
vinny...I feel ur pain when it comes to nyc gas prices but u can't be cheap about it...bc if ur can suffers damage due to low fuel, ur warranty doesn't cover it bc u chose to put 87 in it..and trust me, u don't wanna pay for a new VQ37HR...jus do ur self the favor of getting ur gas near the Palisades mall if u care about price that much, it's cheaper in upstate ny and NJ...
Old Jan 22, 2008 | 05:36 PM
vinnys coupe's Avatar
vinnys coupe
its not that i cant afford it guys, i was just a question if you mix gases would it hurt your engine?
I will be putting super in my car.
fuzzed
Aug 21, 2020 09:35 AM
rk325
Oct 13, 2015 01:51 PM
si_driver
Oct 1, 2015 09:53 AM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
MrRiv
Sep 29, 2015 04:59 PM
