Car won't let me pump gas
happens to me all the time. when you start pumping gas before you pull the trigger all the way set it to the first notch and that always does the trick for me. its letting too much air in if you squeeze the trigger fully. hope this helps
Just bought a 2010 G37S manual with 26k miles and 1st time I tried to fill it up (was almost empty) I couldn't get a single drop in. Went to a different pump and same thing. Couldn't get past 000.000. This was a Shell station I always went to in my Jetta with no problems. Went to a Valero and after trying every angle, speed, and depth I gave up after over 5 minutes, having only put about 2 gallons in. This is absolutely ridiculous. I was thinking there must be switch or button in the cab I had to press or something. There's not, right?
Skyaddict
13
Nov 8, 2018 07:14 PM
SLEV3N
General Tech Questions
Oct 17, 2015 05:58 PM
Thirty_Seven
12
Aug 16, 2015 01:48 PM
350zrunnin12s
Aug 9, 2015 09:55 PM
