SC or Turbo?
Old Dec 10, 2007 | 05:29 PM
BigJohnson's Avatar
BigJohnson
Originally Posted by EightOneZero
With the compression these motors have, I say neither. Unless you pick up a centrifugal SC with a custom pulley (bigger in size of course).
Actually, I would recommend a twin screw compressor supercharger over a centrifugal charger. The screw compressor is the only supercharger to provide a positive displacement design for maximum low-end torque as well as high efficiency for maximum top-end horsepower. Centrifugals and turbos have tremendous lag time during shift points, on-off throttle and off the line boost. While the turbo creates great peak horsepower, turbo lag and high cold start emissions due to the thermal mass are severe drawbacks to the turbo. Roots-type superchargers have been proven to not be very efficient, especially at higher boost levels. Twin screw superchargers have a variety of screw compressors for all types of applications, anywhere from a 75 cubic inch compressor to the 305 cubic inch compressor.
I used to drive a GTP with an Eaton M90 supercharger and I switched to a twin screw. Unbelievable difference. I'm not sure if you can get a twin screw supercharger for the G37 yet though
Cheers
Old Dec 11, 2007 | 01:38 PM
DetroitG37Joe's Avatar
DetroitG37Joe
Supercharger!?!?!
When I first got my G - it was a huge purchase. I knew it wasn't a Z and I wanted to keep her as close to stock as possible...But now I am starting to dream a little - I hope not pipedreams. My cousin has 450 WHP on his s2k with a turbo but his car is always being maintained in the shop but boy do I envy that power and all that on a lil roadster that began with no torque. Turbo is out of the question for me I don't want to F with my G like that.
I am thinkin down the road about a Supercharger (but I am a n00b at hardcore tuning I have only F'ed with I/H/E) closer the end of the 60k warranty maybe around 40k or so, so in about 2-4 years. Now the pros with a supercharger if I am not mistaken are these:
  • Somewhat cheaper than Turbo,more bang for the buck
  • Less complicated + cheaper professional install
  • constant power throughout the powerband rather RPM point kick in
  • Overall less maintenance and less problematic than turbo
  • Less other parts outside of S.C. kit needed to be replaced
  • Less wear on pre-existent stock internals
Correct me if i am wrong the above plus points are just off the top of my head. Who here is vaguely considering Supercharging? Any thoughts about it? How many HP out of the engine do you think we could expect? I am thinking maybe 80-120. Also does one have to do I/H/E + ECU with a S.C. Kit or change out any other internals? Also given the stock profile of the car - is it SuperCharge ready, as in proper room in the engine bay, compatible fuel compression etc. I dunno I'm pretty new to this Again this is all just a possibility with my car. I'll admit I am afraid of doing something drastic with my baby considering Im paying for her in full and also I will only purchase the top of the line - top reputed parts and install from reputed mechanics.
Joe
Tuckermaclain
Oct 5, 2015 11:41 PM
infinitiandb...
Sep 11, 2015 07:57 AM
nethole
Aug 12, 2015 04:08 PM
