Mobil One?
Mobil One?
Anyone using Mobil One or a fully synthetic in their G37? I've been using M1 in my other cars and swear by it (especially in summer and winter with the temp extremes). It will be at least a month before I do the first oil change but would be interested in any comments on synthetics.
I used M1 Full Synthetic in my G35 before I got the G37. I changed my oil with it ever 3750. I will most likely use Amsoil or Royal Purple in the G37. Mobil 1 is great, but I think Amsoil and Royal Purple have a slight advantage.
The Infiniti "premium" maintenance schedule seems waaay excessive and probably doesn't apply to most people, just like the schedule 1 maintenance. I'll be following schedule 2 and will be using M1 after the 1st change as well.
Schedule 1 conditions:
-Repeated short trips of less than 5 miles in normal temperatures or less than 10 miles in freezing temperatures
-Stop-and-go traffic in hot weather or low-speed driving for long distances
-Driving in dusty conditions or on rough, muddy, or salt-spread roads
-Towing a trailer, or using a camper or car-top carrier
mobil one is the only oil i ever used in any of my cars. the only time i changed was with the M3 because they have special formulated castrol for that car. Motul in my bikes. but the G will be getting m1
I am currently using what ever they are putting a Crest Infiniti for the first 15-20K miles and then will switch over to M1. Not quite sure if there is any truth to this but I have heard that M1 or any synthetic could cause a bad break in if used early and may cause more then normal oil use. Sounded like BS but if it not I am pretty sure after 20k the car will be very well broken in.
Just fyi, Corvettes come from the factory filled with M1.
