Review Z1 subframe bushing and diff bushing plus whiteline comparison
About 2 weeks ago I installed the Z1 subframe bushings. These were not terribly difficult to install however Z1 instructions are not very good. Just as a reference point, they show 1 insert going into the bottom of both rear bushings and 1 in the top of the passenger front, mind you the kit ships with a total of 6 inserts...what do you do with the others??? Well after looking at it a realized that the 2 front bushings get an insert on the top and the two rear bushings get an insert on the top and bottom. Some advice, the subframe is fairly easy to drop, an impact gun would be useful here to lower it, start with the front bushings as Z1 suggests. I did the rear first and it caused me to have to drop the rear again to do the front due to less leverage once the rear bushing inserts were installed. You also will benefit from some type of bushing friendly lubricant to ease install. Get yourself a rather heavy rubber mallet too.
So these were a pretty decent upgrade. They helped some with wheel hop and I didn't notice any change in nvh at all. This was with the stock diff bushings still. I can still cause wheel hop at this time however it was slightly improved. I'd say I'm a happy buyer and would suggest these to anyone with the extra cash. Diff bushing would be my first mod however over these.
these.
Diff bushing review will come in next post...
these.
The subframe bushings from Z1 were much easier to install in comparison to the whiteline. With whiteline you have to press the bushing in. With Z1, a little grease and a few whacks from my hammer knocked it right in place. I won't be going over the entire install process as that's been beaten to death already.
Impressions, good fitment, easier install than whiteline, still next to no added nvh.
Overall impressions...
Very good combo for the money. My car is a 7AT and the shifts feel much more solid. Wheel hop can still be an issue if I push her hard. I had whiteline bushings in my previous car by themselves and I'd say the Z1 setup with inserts is superior. Just wish Z1 would improve on their install directions for the inserts (collars).
Wanted to update this...
So overall I think for light track duty and street duty these are a waste. I want to suggest spending the money on the differential brace but I haven't used it myself to give it full backing. That may be a future mod and if I do so I will update this thread or perhaps start a new one.
Let me be clear here, there is nothing wrong with this mod. They are quality pieces and work fine. I just don't want anyone expecting these to fix wheel hop issues because it does not. I was at a decently prepped track the other day and if launching anything near 2krpm or higher (7 speed auto) I would experience wheel hop. Next mod I think will be larger tires.
No, it's not going to be a solid rear bushing, but as an OEM replacement with a slight increase in control, I think they're fine (and worth the price if you already have to be in there.)
The OEM torque converter is set to engage at around 2k rpm. You also have to have a tune or the brake switch mod in order to apply brake and gas at the same time. If you apply the gas very slowly you can raise the ram without engaging the transmission
b2autodesigns
Drivetrain
259
Mar 29, 2018 11:55 AM
4DRZ
12
Mar 12, 2017 10:48 PM
GTSPEC-MARK
Oct 20, 2013 11:42 AM
