DIY: Red Door/Courtesy Light Mod
Old Jan 22, 2017 | 11:41 PM
stanchua's Avatar
stanchua
This is a pretty easy mod and only took me 10 minutes. I didn't have to purchase anything but the cost to start from scratch should still be significantly less than getting red LED bulbs. Did this on my previous car and thought I try this on the G.
Tools needed:
- Red sharpie
- Flathead screwdriver
1. Remove the cover (https://www.myg37.com/forums/d-i-y-i...ion-guide.html)
2. Remove the cover from the housing. There are 4 tabs (2 on each side). Pry them off carefully to separate the cover & housing.
3. Use a red permanent marker to draw/paint the inside side of the cover. Try to cover all areas from the inside. I used this:
4. Reverse above steps (don't wipe the red paint off of course)
5. Enjoy the end result
In the dark
Under the light
Old Feb 7, 2017 | 02:29 PM
Daddy Fat Sacs's Avatar
Daddy Fat Sacs
what in the ****
Old Feb 8, 2017 | 08:26 PM
saywat?'s Avatar
saywat?
they make transparent vinyl film u coulda wrapped fyi
Old Feb 16, 2017 | 09:53 AM
steven92's Avatar
steven92
or have bought a red LED............
Old Feb 16, 2017 | 11:32 AM
saywat?'s Avatar
saywat?
It's a sad day for the g37 community
Old Jul 5, 2019 | 06:19 PM
BULL's Avatar
BULL
Moderador
Cheap mod that if properly done can yield good results.
Alcohol wipe + steady hand+ wide red marker will do.
Problem here is results will decay over time.
The best upgrade for this is red transparent vinyl, for ever lasting, possibly cents more than the marker.
requires patience.
