DIY: G37 Automatic Transmission Fluid Change, Pan Drop/Clean
Old Jul 27, 2015 | 11:29 PM
former520's Avatar
former520
It is good to know that it does not require any special equipment. I was under the impression you needed a computer to read the fluid level like a BMW.
The fill style is the same as a Trooper I had. It was a GM Hydromatic I regularly flushed and found it to be an easy solution. Just pump it up a just past what you think and let the over fill drain out. Way better than trying to read a dipstick.
Old Aug 5, 2015 | 09:49 AM
xpcgamer's Avatar
xpcgamer
I have to ask but everything I have ever heard was to not flush the tranny fluid. Doing a simple drain and refill would be fine. Do you guys just let the transmission do the flush by running the car and then draining it again? This is different then going to a shop and having them put a machine on the front cooler and then flushing that way correct?
Old Aug 5, 2015 | 07:06 PM
This is basically doing a 3x drain & fill to get the majority of the old fluid changed out, this isn't a true flush as you still have some % of the old fluid mixed in. This is based on the Factory Service manual Procedure though so following this DIY is in line w/ what Infiniti recommends.
Old Aug 5, 2015 | 07:52 PM
xpcgamer's Avatar
xpcgamer
At what interval? I am at 41K and aside from normal Oil done at the dealer I am sure this wasn't done.
Old Aug 6, 2015 | 12:00 AM
That's the million dollar question, one that no one seems to have an exact answer
Some say 60k miles, some say 100k, some say never, and then you have cash happy dealers saying 30k. I went to almost 75k, my fluid still was somewhat clear, not burned at all. The one big advantage to the DIY is removing/cleaning the pan, the cleaning of the pan magnets should ensure that they will do a better job at removing any metal fragments and cleaning the residue sticking to the pan definitely couldn't hurt.
Old Aug 9, 2015 | 01:20 PM
LexiG37's Avatar
LexiG37
Is there not a fill plug on top of the transmission to make refilling easier? I'd rather let gravity do some of the work.
Old Aug 9, 2015 | 04:21 PM
No, but those fluid pumps aren't too bad TBH, as long as you have a willing helper that is
Old Aug 12, 2015 | 02:03 PM
guy from norcal's Avatar
guy from norcal
Man this is a great DIY.
Props to Davison and Brad for paving the way for the rest of us.
Old Sep 16, 2015 | 01:56 PM
STUNAG37's Avatar
STUNAG37
Couldn't you use the transmission dipstick hole?
Old Sep 16, 2015 | 02:29 PM
krazyfiend's Avatar
krazyfiend
There is none on the 7AT...Only a bottom fed inlet hole on the transmission itself. Hence why this procedure wasn't really considered DIY until the OP and few others forged ahead and said the heck with needing a specific inlet feed tube/pump system as well as a Consult III to measure transmission fluid temps per the service manual. (Simply measure what drains out and put the according amount back in-- so simple, I can't believe I never thought of that).
If there was a transmission level / dip stick... this procedure would basically be as easy as it is for the 6MT.
Old Sep 18, 2015 | 04:13 PM
STUNAG37's Avatar
STUNAG37
Oh okay. I have a 5at and it has a dip stick so I'll just use that.
Old Sep 19, 2015 | 08:45 AM
davison0976's Avatar
davison0976
Thank you all for the comments and a great discussion. I wanted to post a quick update after crossing a 3000 mile mark since the transmission fluid was replaced. Granted it's not much, the transmission is continuing to operate flawlessly. The shifting continues to be both precise and smooth, as smooth as the Nissan's 7AT can be I suppose, given that it's known as not being the smoothest transmission out there to begin with.
There have been no dash board lights coming up of any kind. Nor anything else that would make me either unhappy or concerned. I drive the car fairly hard on occasion, but not in an abusive way. Plus, this summer has been on a hot side, as I've seen 100F+ ambient temperatures multiple times.
Old Sep 19, 2015 | 12:32 PM
Ditto that^^ got about 3k on mine since as well, no issues, and seemingly better overall performance. Placebo perhaps but at least in my mind it seems to be an improvement.
Old Oct 11, 2015 | 09:47 AM
  #29
Bravo at's Avatar
Bravo at
Thank you for this DIY. Worked well. Like you, I had some fine medals and some break aways. Used Royal Purple and swapped the OEM pan out for the Level 10 pan.
Old Oct 11, 2015 | 12:03 PM
  #30
Nice!
Got a pic or a link for that pan, and does it hold more ATF and/or has cooling fins?
