Butyl sealant tape for headlight sealing
Old Mar 22, 2015 | 06:00 PM
So I have yet another problem with my headlights (Thanks 180 Customs! ). An obscene amount of water (much more than condensation) got inside and caused the HID to stop working. I am fixing it myself because that's the most feasible solution.
Is there anywhere in a local store to find the right stuff? If not, does anyone have leftover butyl sealing tape that they don't need that they can sell me? I can buy it online and it's not expensive but since I only need enough to seal one headlight I figured some member might have surplus form a project that they might want to sell. Let me know if there's a local place that sells it (Houston is a big city) or if I need to get it online. Thanks.
Old Mar 22, 2015 | 06:18 PM
I'm out of town until Tuesday night but I have some leftover from a lifetime shed I build. They had rolls of the butyl tape to seal the skylights and I'll be happy to send you the rest of the roll, should be enough for your light. If you can hang on 'til then I'd be happy to send it to you on my dime.
B
Old Mar 22, 2015 | 08:13 PM
vqsmile's Avatar
vqsmile
I would imagine you could also source it locally from an auto-body paint and supplies store. There are usually a few in any given area.
Old Mar 22, 2015 | 10:51 PM
Thanks. Brad, is what you have like OCI butyl tape? That's what I need. I got my headlight working again with a bit of work and a new ballast. I'm sure I can do a better job of sealing it than the clowns at 180 Customs did.
Old Mar 23, 2015 | 12:01 AM
Jeremy,
This is what the tape roll looks like, and is about 3/4 to an inch wide black rubber, wish I was at the house so I could tell you for sure how much I have left. I assume all butyl rubber tape is the same, but Since the application is for sealing skylights I would think they'd be up for sealing headlights.
Heng's 1" Off White Butyl Rubber Tape - 20' Roll - Tapes & Seals - RV Maintenance
Old Mar 23, 2015 | 01:50 AM
I believe that will work just fine. When you get home, PM me your PayPal. I'm not going to let you ship it on your dime, the whole point of not buying it from Amazon was to let a fellow member clear it out of their garage and make a buck in the process.
Old Mar 23, 2015 | 07:46 AM
mdaaboul313's Avatar
mdaaboul313
Hey Jeremy, I got some at Advance Auto Parts.
3M Window-Weld Round Ribbon Sealer, 3/8" x 15 ft Kit 08612: Advance Auto Parts
Old Mar 23, 2015 | 09:54 AM
Originally Posted by mdaaboul313
That looks like it'll work. I'm going to check it out. Thanks.
Old Mar 23, 2015 | 08:20 PM
Got it! I picked some up at the local Advanced. This looks like exactly what I need. I appreciate the heads up.
Old Mar 24, 2015 | 12:14 AM
Cool, hope that moisture is a thing of the past.
Old Mar 24, 2015 | 02:07 AM
NeverBoneStock's Avatar
NeverBoneStock
3 M automtive weather strip works better. I have tried all the above and when I used this stuff 5 years later and zero leaks
Old Mar 24, 2015 | 08:37 AM
mdaaboul313
Hey Jeremy, also, if you havent sealed it up yet, you can put in a couple of those silica gel packs that come in packages. It'll help keep the moisture out.
Old Mar 24, 2015 | 10:40 AM
You mean foam tape weatherstrip?
Old Mar 24, 2015 | 10:54 AM
It's sealed up but that's temporary. repaired the HID because I need to get it inspected before the end of the month and then I have to open it up again to repair my fog light (broke the piece where the ground wire goes). Fog lights don't need to be functional to pass safety inspection so I'll go back in to fix those after I find the part I need.
Wouldn't the gel packs move around inside the housing or get too hot? Wouldn't they be pretty much useless after the first moisture they absorbed?
Old May 19, 2015 | 03:26 AM
NeverBoneStock
Not the foam
37
Oct 17, 2020 11:12 AM
Rybitron
Nov 18, 2015 03:11 PM
2K1 6T8
Oct 6, 2015 07:40 PM
Allboutcali
Sep 26, 2015 03:43 PM
