DIY: Painting a Shift Pattern
Old Aug 26, 2014 | 03:06 PM
Thirty_Seven's Avatar
Thirty_Seven
I know this only applies to aftermarket shift *****, but I figured I post it here for you guys just in case.
So I ordered this shift **** off eBay and really didn't like the way the red clashed with the rest of the interior. They didn't have it in white or black so I figured I'd paint it once it came in. I painted over the red without cleaning it before hand (stupid idea) and it came out really bad, so I gave it another go with white and this time it came out much better. It been like that for a few weeks with no sign of smudging or anything.
Disclaimer: If the actual **** itself is painted, the acetone will strip the paint off. My suggestion is to clean it with some soap and water and just paint over it and wipe the excess away. Lick your finger and rub around the numbers to wipe the excess, don't let it sit too long and dry.
What you'll need:
-Touch up paint (or any other paint really)
-A thin brush
-Nail polish remover (Acetone)
-Q-Tips
-Paper towels
Steps:
1. Strip the old paint off using the acetone and the Q-Tip. Be thorough.
2. Apply the new paint by painted a large area over the numbers then wiping away the excess with a paper towel. The paint should remain inside of the indentations of the numbers.
3. Let each coat dry for 5 minutes and re-apply 3-4 times.
4. Using the Q-Tip dipped in acetone, wipe away any excess paint around the numbers.
5. Let it dry for a few hours.
It really shouldn't take more than 15 minutes and it's really simple to do. I had all the supplies lying around my house already.
Here's the video of the process.
Old Sep 24, 2014 | 03:42 PM
Need 4 Speed's Avatar
Need 4 Speed
Nice write up!
37
Oct 17, 2020 11:12 AM
ck1109
Oct 15, 2015 11:06 PM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
Jonesmeister11
Sep 27, 2015 08:28 PM
Sep 25, 2015 01:38 PM
