DIY: Front Bumper Removal/install
Old May 8, 2014 | 08:54 AM
  #46
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
Originally Posted by pontiacstogo
Well yeah - I wouldn't remove the bumper if I was just doing the grill only. But given that I'll be doing the midnight grill AND the OEM lip, I wondered if removing the bumper might make both jobs easier.
If you're just using self tapping screws, I actually think not taking off the bumper is better. When you pull the bumper off, it flexes quite a lot and won't sit *exactly* how it sits on the car. If you attach a lip with it off the car, it probably won't fit perfectly when you try to reattach everything.
Old May 8, 2014 | 08:58 AM
  #47
pontiacstogo's Avatar
pontiacstogo
Aaah - good point. Hadn't thought about that. Oh well, guess I'll flop around on the floor and try and do it the old fashioned way. Thanks.
Old May 17, 2014 | 06:46 PM
  #48
MistaYoung's Avatar
MistaYoung
Damn, this is easy I'm gonna do this soon...
Old Nov 3, 2014 | 05:25 PM
  #49
Global Reach's Avatar
Global Reach
I just installed the Takeda intake and there are two extra screws that you have to remove when you take the fender liner out. It is on the same line as the first screw right at the edge of the fender and bumper, but this screw is further inside by the head light. I used a 10mm deep well with an extension to get to it.
I did not see the above mentioned so I will put it out there. I did what the OP posted and the bumper wouldn't budge. Did some exploring and that when I found 2 more screws. And I say screw because they screw into plastic wing nuts of some kind. They are definitely not bolts. I wish I took pics to but I didnt.
Old Nov 25, 2014 | 10:43 PM
  #50
TreyG777's Avatar
TreyG777
DIY: Bumper Install/Removal
There is an extra bolt not shown in the original post within the engine bay. It is located on the left and right side with the black arrows. I used an extended 10mm ratchet to remove this. Also there are TWO bolts (located with the red arrow) located inside the wheel well in which i used the same extended ratchet to remove these. All in all for my first time removing the bumper it took me about an hour. Great DIY otherwise. I have a 2011 g37 sedan as well.
Attached Thumbnails Front Bumper Removal/install-20141125_153332.jpg   Front Bumper Removal/install-20141125_153731.jpg
Old Feb 13, 2015 | 10:17 PM
  #51
sLADe781's Avatar
sLADe781
Hey guys, while taking off the bumper tonight, one of the clips on the bumper bracket (passenger side) that holds the bumper broke off.
Note that that piece has 2 clips that the bumper goes into and the upper clip broke. Do I need to buy a new bracket because of that broken clip or would the bumper still hold? Would I be able to super glue or melt the plastic back together? Anyone know the part number for the bracket by any chance?
Please let me know...thanks in advance.
Old Jun 19, 2015 | 01:20 PM
  #52
milkcow500's Avatar
milkcow500
I notice on one side of my car, the side where the bumper and hood meet isn't exactly flush. It's a bit angled. Is there a way to fix this?
Old Jan 19, 2016 | 07:51 PM
  #53
lobuzz311's Avatar
lobuzz311
Originally Posted by 1cleanG
3. Then remove the first 3 or 4 pegs holding the seal around the outter edge of the engine bay. There are rubber pegs that simply come out w/ a flathead or a tool. This allows access to the bumper bracket.
Does anyone have the part # for these pegs / clips? Mine were not cooperating, and I broke a number of them pulling off my bumper. I searched through every part diagram I could think of, but none of them have that rubber trim, let alone the clips.
Any help would be greatly appreciated!!!
Old Jan 26, 2016 | 04:21 PM
  #54
jcote003's Avatar
jcote003
Awesome write up. Thanks!
Old Aug 11, 2016 | 02:24 AM
  #55
Ocgotti's Avatar
Ocgotti
I need that part too
Hey hows it going ..i really need help too ..did you find out the part number on that white part?
Old Aug 25, 2016 | 11:16 PM
  #56
SneakyBrown's Avatar
SneakyBrown
This came in super handy! Thanks!
Old Jul 20, 2017 | 09:49 PM
  #57
ericxd's Avatar
ericxd
FYI, if anyone has a 2010 and up sedan, step 8 was a pain in the *** as there is another screw inside the first screw...PAIN IN THE ***...
Old Jul 20, 2017 | 09:50 PM
  #58
ericxd's Avatar
ericxd
I left it, just tug the rubber in and call it a day. Don't need it unless you are very OCD lol
Old Oct 6, 2018 | 05:14 PM
  #59
Don0514's Avatar
Don0514
Headlight
I have a 2012 infiniti g37 sedan i have a question my passager side headlight popped out some and I was wondering is the only way to fix it do I have to take my front bumper all the way out? Please help me with this problem thank you
Old Jun 30, 2020 | 10:53 AM
  #60
GodlikeRage's Avatar
GodlikeRage
4. Next remove the screw from the bumper bracket (10mm). You'll see that all that is holding it in place is a piece of plastic. The bracket itself slides right out.(black screw on silver plate in photo)
(NOTE FOR REINSTALLATION: be careful with reassembling the bumper bracket, it screws into plastic, and it will break if overtightened)
Attachment 172587
Can't get this damn screw out, it just spins in place....... I've tried prying it, impact, etc and nothing... I'm about to just break it and buy another..
