HELP: DIY - 2010 Sedan Fog Light rewire
Old May 19, 2010 | 01:52 PM
leeI35G35's Avatar
leeI35G35
Hey guys - I have been searching the DIY threads and I am trying to find a way to rewire the fog lights for MY10 Sedan. Has anyone accomplished this task on the 2010 Sedan?
I would like my fogs to be able to turn on when using the parking lights, or Headlights. Thx...
P.S. I apologize if there is already a thread about the MY10 Sedan. I did search...plz point me to the correct thread.
Old May 19, 2010 | 02:21 PM
SkyMG37x's Avatar
SkyMG37x
While I haven't done this on my 2009 (and the 2010 should have the same design) I have done this on many prior cars.
The reason I haven't done this on my G is because of the way the system is designed. It's all digital, meaning the decision to enable the FOGs comes from the BCM to the IPDM E/R via the CAN Bus, which in turn has digital electronics to manage the Fog relay. It's not as simple as moving the enable pin on the relay from the Headlight circuit to the Parking Lamp circuit.
There is a company that sells a module that you plug in between the headlight multiswitch harness and the BCM to change the digital signal to do what you want. I believe this is it: KP Technologies
Old May 19, 2010 | 08:39 PM
leeI35G35's Avatar
leeI35G35
Yeah I have done this on plenty of my other infiniti's however the g-series is a little different. It was breeze with my I35 and Qx4 as I just tapped into other wires. I have not the slightest clue on what to do now. I will look into the KP Technologies switch. Unless some can chime in on some wire reconfiguring
superjoey
31
Mar 22, 2023 11:56 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
sydnrusty
Nov 21, 2015 10:42 PM
bikerjosh
Aug 19, 2015 11:26 PM
