Help Masking tape residue, how to remove?
Old Sep 22, 2016 | 12:29 PM
Kris9884's Avatar
Kris9884
I just bought an older Mazda Protégé to daily as I build my G coupe and the last owner was careless to say the least. I am down to the last little fix until its completely drivable and done. The trunk wouldn't stay closed and locked before so he used clear masking tape across the entire trunk to keep it closed. I have fixed the trunk and removed the tape but the residue has been sun baked on there for almost a year. I have tried alcohol, goo gone, WD40 and nothing has worked. The stuff is like concrete hard now. Short of just wet sanding it all off is there any buffer pads or chemicals you recommend using first? For the record, this car has dents and dings and sun burn paint everywhere so this wont be a detailing queen, just want the really tacky looking tape residue removed. Thanks for any help you can offer!
Old Sep 22, 2016 | 01:01 PM
guy from norcal's Avatar
guy from norcal
Try an eraser wheel. I used one on the G and my wifes yukon for removing side trim glue and when removing the emblems.
Old Sep 22, 2016 | 02:09 PM
Kris9884's Avatar
Kris9884
That looks perfect. I assume just hit it with the usual compound and buff then wax after and it should be ok?
Old Sep 22, 2016 | 07:05 PM
hobbs's Avatar
hobbs
Mr CleanŽ | Magic Eraser Original
Old Sep 22, 2016 | 09:43 PM
DO NOT use a magic eraser on your car's paint. It will scuff the hell out of the paint because it is extremely abrasive. That's a horrible suggestion.
Old Sep 23, 2016 | 10:11 PM
saywat?'s Avatar
saywat?
id wet sand, compound, and wax
Old Sep 24, 2016 | 03:22 PM
guy from norcal
Yes sir.
Old Nov 1, 2016 | 08:54 PM
s13envy's Avatar
s13envy
bug and tar remover has worked well for me in the past. spray it on and let it sit for about 5 min. should wipe right off.
Oct 7, 2024 11:28 AM
Stellpflue37
Sep 19, 2016 09:36 PM
celwin
Sep 11, 2016 10:47 AM
pwcracer
Sep 7, 2016 02:43 PM
lil_dave
Sep 5, 2016 07:36 PM
