Windshield Polishing
Old Jan 2, 2016 | 04:10 PM
Victory's Avatar
Victory
My windshield looks terrible in bright sunlight. Is anyone aware of a really good product that can take out swirls and scratches? Would be using a porter cable.
Old Jan 2, 2016 | 05:42 PM
Thirty_Seven's Avatar
Thirty_Seven
You're not gonna get much done with a Porter Cable. Not that it's a bad machine but glass is just too thick and strong for it to work well. You could try this if you really want.
Start with a car polish and a heavy cutting pad. This should take out swirls or VERY light scratches. If this doesn't work, go more aggressive.
Buy some Rayon glass polishing pads and some Ceriglass and try polishing with that. This will get the glass very clear and remove almost all light scratches and swirls.
This is the most you can do with a DA. You can try these same steps with a rotary to get better results but if your glass is pitted or has small chips, these will never come out and replacement is necessary.
Old Jan 3, 2016 | 12:58 PM
Upscale Speed's Avatar
Upscale Speed
do you have glass insurance? I do and deductible is $100.00. I'd just replace the windshield and then protect it with some Pinnacle Glass Works Glass Sealant. Use it every month, super easy to wipe on and buff off and you'll be golden. That would be my suggestion.
Old Jan 3, 2016 | 06:49 PM
Detailed Image's Avatar
Detailed Image
Auto Detailing Expert
^Great advice... long story short, there isn't a whole lot that can be done with polishing. Glass is much harder than paint, and you cannot achieve the same type of defect removal that you can with a DA machine on clear coat paint. If the windshield is in poor shape, it may just be better to replace it.
Zach McGovern
Detailed Image Ask-A-Pro Blog Author
Attention to Detailing - Peoria, IL
Old Jan 5, 2016 | 11:34 AM
Victory's Avatar
Victory
Might try the rayon pads and ceriglass as a last ditch effort before replacement (glass coverage with my insurance is garbage, basically just a mild discount with safelite). while there is some pitting and i don't expect that to help, the main issue is when the sun hits it at the right angle the light swirls and scratches are awful.
Old Jan 5, 2016 | 11:43 AM
Selym's Avatar
Selym
Cerium oxide will remove enough material to get rid of light scratches (e.g. the scratches caused by running the wipers on a dry windshield).
I'd avoid replacement unless it's absolutely necessary, as there is always the risk of leaks and damaged weather stripping.
Myles
Old Jan 5, 2016 | 11:51 AM
Victory's Avatar
Victory
Myles
I do sales so i put on a ton of hwy miles. At some point, a truck will kick a rock into my windshield. It's inevitable. So, i'm fine with polishing and just waiting for that day.
Old Jan 19, 2016 | 06:04 AM
rj8dan's Avatar
rj8dan
Another vote for using ceriglass. It can really remove minor scratches on windshield and side windows.
Detailed Image
Lighting/Cleaning Products
Dec 31, 2015 08:57 AM
User 122320
Dec 26, 2015 09:01 AM
MichaelYYZ
Dec 19, 2015 10:20 PM
TheLocNar
General Tech Questions
Dec 2, 2015 04:00 PM
Detailed Image
Dec 1, 2015 07:08 AM
