Sanding and re-clear coating wheels
Old Apr 29, 2015 | 01:31 AM
Flakman's Avatar
Flakman
I have to fix some curb rash on my wheels from the previous owner. It's just on the rim which would be fairly simple to deal with. However, there are spots on other parts of the wheel where the clear coat is peeling. I was thinking that I could just sand down the rim of the wheel, then sand down the peeled areas until the transition is smooth, then spray the whole wheel with clear. Have never done anything to this depth to fix painted or clear coated areas. Just need to see if my thinking is correct or if I should take further measures regarding the rest of the wheel.
Thanks
Old Apr 29, 2015 | 10:40 PM
Roadrash666's Avatar
Roadrash666
Thanks
No, don't sand it. The hyper silver finish is a three stage application, if you sand through the silver anywhere on the wheel you're screwed. A mobile rim repair service can get a close match but nowhere near perfect. Google hyper silver wheel finish, and you'll have a much clearer idea of what you're dealing with. My wife just had all 4 wheels powder coated on her 370 for right around 500 bucks. That was in a dark metallic silver finish, not hyper silver though. Good luck! The clear was all jacked up on my OEM wheels, I just used it as an excuse to put something different on there. Before and after
Attached Thumbnails Sanding and re-clear coating wheels-photo974.jpg   Sanding and re-clear coating wheels-030.jpg
Old Apr 30, 2015 | 12:13 AM
Flakman's Avatar
Flakman
Ah. These wheels are machined except for the black part, not the hyper silver.
Old Apr 30, 2015 | 12:30 AM
Roadrash666
My bad, I assumed they were oem. That changes things considerably. Post pics when they are finished.
xpcgamer
Sep 7, 2015 07:10 PM
Sylo
Sep 3, 2015 04:44 PM
ZachThomas
Sep 3, 2015 01:40 PM
