Order with DI
Old Apr 12, 2011 | 02:17 PM
r6rider211's Avatar
r6rider211
Order with DI
About to checkout with my order from Detailed Image... here is what i am planning on getting:
<TABLE id=checkout-items cellSpacing=0 cellPadding=0 border=0><TBODY><TR><TD></TD><TD></TD><TD align=right>Price</TD><TD align=right>Qty</TD><TD align=right>Total</TD></TR><TR id=cart-item-425-1><TD></TD><TD>DI Packages Porter Cable 7424 XP, Meguiar's Polish and Hydro Pads</TD><TD align=right>$214.99</TD><TD align=right><FORM id=form-update-qty-425-1 action="" method=post><INPUT class=update-qty-inputs onkeypress="return disableEnterKey(event)" id=update-qty-425-1 maxLength=3 onchange="updateCartQty('425', '1')" value=1></FORM></TD><TD align=right>$214.99</TD></TR><TR id=cart-item-263-1><TD></TD><TD>Lake Country Porter Cable 7424 Backing Plate for 4 Inch Pads - 85 mm</TD><TD align=right>$12.99</TD><TD align=right><FORM id=form-update-qty-263-1 action="" method=post><INPUT class=update-qty-inputs onkeypress="return disableEnterKey(event)" id=update-qty-263-1 maxLength=3 onchange="updateCartQty('263', '1')" value=1></FORM></TD><TD align=right>$12.99</TD></TR><TR id=cart-item-458-3><TD></TD><TD>Lake Country Hydro Tech Crimson Ultra Fine Finishing Pad - 4 inch</TD><TD align=right>$5.99</TD><TD align=right><FORM id=form-update-qty-458-3 action="" method=post><INPUT class=update-qty-inputs onkeypress="return disableEnterKey(event)" id=update-qty-458-3 maxLength=3 onchange="updateCartQty('458', '3')" value=1></FORM></TD><TD align=right>$5.99</TD></TR><TR id=cart-item-406-3><TD></TD><TD>Lake Country Hydro Tech Cyan Light Cutting and Polishing Pad - 4 inch</TD><TD align=right>$5.99</TD><TD align=right><FORM id=form-update-qty-406-3 action="" method=post><INPUT class=update-qty-inputs onkeypress="return disableEnterKey(event)" id=update-qty-406-3 maxLength=3 onchange="updateCartQty('406', '3')" value=1></FORM></TD><TD align=right>$5.99</TD></TR><TR id=cart-item-205-1><TD></TD><TD>Blackfire Wet Diamond with Polycharger - 16 oz</TD><TD align=right>$29.99</TD><TD align=right><FORM id=form-update-qty-205-1 action="" method=post><INPUT class=update-qty-inputs onkeypress="return disableEnterKey(event)" id=update-qty-205-1 maxLength=3 onchange="updateCartQty('205', '1')" value=1></FORM></TD><TD align=right>$29.99</TD></TR><TR id=cart-item-40-1><TD></TD><TD>Poorboy's World Wheel Sealant - 8 oz</TD></TR></TBODY></TABLE>
The package includes 6" backing plate and 2 Cyan light cutting, 2 Crimson ultra fine cutting, counter weight ....
Planning on doing first detail this weekend... is there anything else your would recogmend or should I be good. First timer.... also i have a BLACK G37s ... would you recogmend a WAX rather then this sealer?
thanks!
Old Apr 12, 2011 | 06:53 PM
r6rider211's Avatar
r6rider211
<TABLE class=tborder id=post3109988 cellSpacing=0 cellPadding=6 width="100%" align=center border=0><TBODY><TR vAlign=top><TD class=alt1 id=td_post_3109988 style="BORDER-RIGHT: #ffffff 1px solid">Changed a few things ^^^^....
<TABLE id=checkout-items cellSpacing=0 cellPadding=0 border=0><TBODY><TR><TD></TD><TD align=right>Price</TD><TD align=right>Qty</TD><TD align=right>Total</TD></TR><TR id=cart-item-425-1><TD></TD><TD>DI Packages Porter Cable 7424 XP, Meguiar's Polish and Hydro Pads</TD><TD align=right>$214.99</TD><TD align=right><FORM id=form-update-qty-425-1 action=https://www.myg37.com/forums/ method=post><INPUT class=update-qty-inputs onkeypress="return disableEnterKey(event)" id=update-qty-425-1 maxLength=3 onchange="updateCartQty('425', '1')" value=1></FORM></TD><TD align=right>$214.99</TD></TR><TR id=cart-item-263-1><TD></TD><TD>Lake Country Porter Cable 7424 Backing Plate for 4 Inch Pads - 85 mm</TD><TD align=right>$12.99</TD><TD align=right><FORM id=form-update-qty-263-1 action=https://www.myg37.com/forums/ method=post><INPUT class=update-qty-inputs onkeypress="return disableEnterKey(event)" id=update-qty-263-1 maxLength=3 onchange="updateCartQty('263', '1')" value=1></FORM></TD><TD align=right>$12.99</TD></TR><TR id=cart-item-205-1><TD></TD><TD>Blackfire Wet Diamond with Polycharger - 16 oz</TD><TD align=right>$29.99</TD><TD align=right><FORM id=form-update-qty-205-1 action=https://www.myg37.com/forums/ method=post><INPUT class=update-qty-inputs onkeypress="return disableEnterKey(event)" id=update-qty-205-1 maxLength=3 onchange="updateCartQty('205', '1')" value=1></FORM></TD><TD align=right>$29.99</TD></TR><TR id=cart-item-40-1><TD></TD><TD>Poorboy's World Wheel Sealant - 8 oz</TD><TD align=right>$14.39</TD><TD align=right><FORM id=form-update-qty-40-1 action=https://www.myg37.com/forums/ method=post><INPUT class=update-qty-inputs onkeypress="return disableEnterKey(event)" id=update-qty-40-1 maxLength=3 onchange="updateCartQty('40', '1')" value=1></FORM></TD><TD align=right>$14.39</TD></TR><TR id=cart-item-407-3><TD></TD><TD>Lake Country Hydro Tech Tangerine Ultra Fine Polishing Pad - 4 inch</TD><TD align=right>$5.99</TD><TD align=right><FORM id=form-update-qty-407-3 action=https://www.myg37.com/forums/ method=post><INPUT class=update-qty-inputs onkeypress="return disableEnterKey(event)" id=update-qty-407-3 maxLength=3 onchange="updateCartQty('407', '3')" value=1></FORM></TD><TD align=right>$5.99</TD></TR><TR id=cart-item-458-1><TD></TD><TD>Lake Country Hydro Tech Crimson Ultra Fine Finishing Pad - 6.5 inch</TD><TD align=right>$11.99</TD><TD align=right><FORM id=form-update-qty-458-1 action=https://www.myg37.com/forums/ method=post><INPUT class=update-qty-inputs onkeypress="return disableEnterKey(event)" id=update-qty-458-1 maxLength=3 onchange="updateCartQty('458', '1')" value=1></FORM></TD><TD align=right>$11.99</TD></TR><TR id=cart-item-458-3><TD></TD><TD>Lake Country Hydro Tech Crimson Ultra Fine Finishing Pad - 4 inch</TD></TR></TBODY></TABLE>
Going to use the Tangerine Ultra fine pad with the M205 and then follow up with Crimson for the Sealent... is this correct... or should I get other pads for what I am doing... I am not really going to use the M105 and the "blue" pad that comes in the kit the first time as I would like to get used to using the PC first... <!-- google_ad_section_end -->
<!-- / message --></TD></TR><TR><TD class=alt2 style="BORDER-RIGHT: #ffffff 1px solid; BORDER-TOP: #ffffff 0px solid; BORDER-LEFT: #ffffff 1px solid; BORDER-BOTTOM: #ffffff 1px solid"> </TD><TD class=alt1 style="BORDER-RIGHT: #ffffff 1px solid; BORDER-TOP: #ffffff 0px solid; BORDER-LEFT: #ffffff 0px solid; BORDER-BOTTOM: #ffffff 1px solid" align=right><!-- controls --></TD></TR></TBODY></TABLE>
Old Apr 13, 2011 | 09:11 AM
philter25's Avatar
philter25
Tangerine with M205 - 2 pads and polish that come with the kit
Crimson with sealant - 1 pad that you order seperately
Cyan with M105 - 2 pads and polish that come with the kit
That is the correct combination and exactly what I would use.
I have the poorboys wheel sealant and I was the only person on DI to give it a negative review. It works well, but its rather time consuming to put on. I would recommend adding a foam applicator pad. Makes applying it much easier.
DI Accessories Foam Applicator Pad | Detailed Image
1.49 well spent to keep the pink sealant from getting everywhere.
And I hope you have good microfiber towels.
Other than that, your order looks good. I have a BO G37 and I havent had the need to use the M105 on my car yet. The M205 polish can get out swirl marks if you take your time and it finishes down nicely, so I havent been using my finishing polish on it. The M205 makes a very nice 1 step polish.
Old Apr 13, 2011 | 01:00 PM
r6rider211's Avatar
r6rider211
Thank you so much for your help... will be placing order today hopefully!
Old Apr 13, 2011 | 03:36 PM
r6rider211's Avatar
r6rider211
Just placed order with Detailed Image ... Can't wait to detail on Saturday.
Old Apr 14, 2011 | 03:19 PM
Detailed Image's Avatar
Detailed Image
Auto Detailing Expert
Thank you for the order I appreciate the support!
Greg @ DI
Old Apr 14, 2011 | 03:25 PM
Detailed Image
Hopefully the Wheel Sealant still worked well for you but depending on your wheel it can take a bit of time to apply. If you want something faster I HIGHLY recommend the Optimum Opti-Seal & Free Yellow Foam Applicator. Spray it on the wheel or your applicator and spread it extremely thin and you are DONE. It dries clear and requires no removal. The protection is durable and you can also use this product on your paint, glass, headlights.
Old Apr 14, 2011 | 05:01 PM
philter25's Avatar
philter25
I was planning on giving the spray on sealant a shot once I finished the jar of poorboys. And the poorboys did work very well, the only reason I get it a "no, I would not buy it again" was because it took a lot of time on the stock wheels to apply. For my wife's 5 spoke RAV4, it take a few minutes, but for all the nooks and crannys of the G37 wheels, it just took a little too much time for my preference.
Once its on, it works like a charm and I have no complaint with the actual product itself, it does a great job, just the application was a little too long for my preference.
BurtoN86
Nov 3, 2015 04:40 PM
MrRiv
Sep 29, 2015 04:59 PM
Detailed Image
Lighting/Cleaning Products
Sep 28, 2015 07:02 AM
pal51961
Sep 27, 2015 08:38 PM
Rick in NC
Sep 3, 2015 11:14 PM
