PC vs Flex Orbital Buffers
I have been considering purchasing a random orbital buffer such as the PC 7424 for quite some time. Now I understand the the Flex is available and may be a better option. I reviewed the comparison on the new and improved Detailed Image website, and as best as I can tell, the Flex has a higher speed, trigger control for the various speeds, and you do not need a backing plate to attach the various pads.
I did notice that the Flex starter is more than a PC starter kit and wanted to know what people's experiences were for those that bought a Flex and is it worth paying more money for it?
Thanks
Thanks
Thanks
Thanks
I think the Flex is worth the difference in price not only because of the time you are going to save with the Flex, but the level of correction is much higher in a much shorter period of time. The PC will take you twice as long to remove as many imperfections as the Flex. With the PC you'll reach a point where it's difficult to remove deeper imperfections. The Flex on the other hand, has so much more power and a strong motor that you can apply heavy pressure to, you can literally remove almost every imperfection in your paint with the right polish and pad combination.
The one thing the PC has over the Flex is the ability to use smaller backing plates with smaller pads. This can help you get in those tighter areas of the vehicle much easier.
If your budget stretches to the Flex buffer, go for it. It'll also save you from getting the PC, using it a few times, wondering what the Flex can offer and how much time you'll save and buying both buffers. Here's what some of our customers have to say after reviewing the Flex 3401.
Hope this helps!
George
Thanks
Thanks
Thanks everyone....looks like the Flex is the way to go.
One final question...for a person that has never used an orbital buffer, would the Flex pose a greater risk to damage your paint because of its higher power? My G's paint is really in good shape so I can't see why I would need the higher speed.......
Enjoy the Flex and more importantly, your new paint!
George
Traveling Administrator
I've got both a PC and a Flex and I just love the Flex compared to the PC. Without repeating what has already been stated, the Flex is just a more efficient tool to use.
You hit most of the key points comparing the Flex XC3401VRG and the PC 7424.
Hope this helps!
George
Hope this helps!
George
Unfortunately, Flex will not allow discounts lower than MAP pricing of $299.99. Check out some of the Flex packages we offer for some good savings.
One of my favorite Flex packages is $80 off (almost 20% off) and includes one of my favorite Menzerna polish combos along with 8 pads (4 pads for each step). The package includes:
You certainly wouldn't be disappointed with that package and includes everything you'd need to remove a majority of imperfections from your paint while finishing to a high level of depth and gloss. It's also our highest discounted Flex package I believe since we never adjusted the price when the Flex went up to $299.99.
Maybe that package is a good fit for your needs. If you want to swap out some of the pads for other colors, I can make that happen too, but I'd advise keeping the 4 of each color for maximum results.
Let me know if there's anything else I can help with.
George
- Flex XC3401VRG
- Menzerna Super Intensive Polish 32oz
- Menzerna PO106FA 32oz
- 4x White Polishing Pads
- 4x Orange Light Cutting Pads
George
