Buying a 2013 Xs in 2 weeks. PPi produced a slew of codes. Should I buy it?
Hello "Possible" Future Car family,
I have my heart set on a 2013 G37Xs w/ 71k on the clock for $19k. It was checked out by a Japanese Car Tuner Shop and had number of codes returned. My goal is to have the items resolved less the price of the car. Can you all take a look and let me know if the repairs are something I should pursue or drop this like it's hot?
Thank you very much!
CODE SCAN RESULTS
Systems Analyzed: 13
Systems w/ Codes
Antilock Brakes - ABS Codes
C1109 Battery Voltage Out of Range
Body Control Module
B2562 Low voltage - History Code
B2601 Shift Position - History Code
B260A Ignition Relay - History Code
C1704 Low Pressure Left Front - History Code
C1705 Low Pressure Right Front - History Code
C1706 Low Pressure Right Rear - History Code
C1708 No Data Received from Left Front - History Code
C1709 No Data Received from Right Front - History Code
C1710 No Data Received from Right Rear - History Code
C1711 No Data Received from Left Rear - History Code
Intelligent Cruise Control/Advanced Driver Assistance System - Codes
C1A14 ECM Circuit
C1A16 Radar Stain
Tire Pressure Monitor - Codes
B2562 Low Voltage
The PPI also noted that the Backup Sensor button was flashing.
CODE SCAN RESULTS
Systems w/ Codes
Body Control Module
C1A14 ECM Circuit
C1A16 Radar Stain
B2562 Low Voltage
FlState
14
Apr 8, 2013 01:17 PM
