Martinez1041 Build Thread
Old Jan 9, 2024 | 06:14 PM
  #61
Martinez1041's Avatar
Martinez1041
Finally got around to putting on the paddles today. Had to trim some of the new steering column cover because it wasn’t allowing the paddles any space to move. I’m gonna guess that’s because these are off a Nissan maxima. I paid $44 for these paddles off 2013 maxima
Old Jan 30, 2024 | 10:32 PM
  #62
Martinez1041
Got this wireless magnetic phone charger from z1. Pretty cool. As soon as you place it on the magnet it starts charging but also connects to the Bluetooth for music
Old Jan 30, 2024 | 10:34 PM
  #63
Martinez1041
Got the z1 “race” intake. I went with the 2.5 inch tubes because 3 requires a tune and I’m not ready for that yet.
Old Feb 6, 2024 | 11:10 PM
  #64
Martinez1041
Z1 intake install.
Old Feb 7, 2024 | 10:37 PM
  #65
Martinez1041
all done
Old Feb 8, 2024 | 09:13 AM
  #66
camopaint0707's Avatar
camopaint0707
oh that intake setup is HOTTTTTTTTTTTTTTTT
Old Feb 9, 2024 | 02:35 AM
  #67
Martinez1041
not sure if your being sarcastic or not.
Old Feb 9, 2024 | 07:12 AM
  #68
Good job on the intakes, OP!
Have you considered using filter bags?
Old Feb 9, 2024 | 09:57 AM
  #69
Martinez1041
thank you good sir. Very much appreciated. Are you talking the hydro lock bags?
Old Feb 9, 2024 | 10:46 AM
  #70
Yep. I don't have a long-tube intake with exposed filters, but if I did then I'd absolutely research getting bags over them.
So what is keeping the filters from banging around there on the frame? I don't see any support brackets. And not sure I'd trust those worm-gear clamps. Maybe some T-bolts?
Looking back in your thread... Berk cats, megan y-pipe, and Z1 long toooob intake... are you gearing up for a tune?
Old Feb 9, 2024 | 10:55 AM
  #71
rotarymike's Avatar
rotarymike
Moderator in Moderation
filter-wears is the brand the motorcycle people like, and I've had no issues with them. About $30 per filter sock.
Old Feb 9, 2024 | 11:41 AM
  #72
Martinez1041
yeah I kinda jumped the gun and put these on without the hydroshields. It’s definitely something I’m going to get very soon. Til then I just won’t drive it in the rain.
As far as what’s keeping it in place, when the tubes go through the radiator core it’s a tight fit. Very tight fit. So tight in fact that that is what’s keeping it there. But like you I had my concerns about the filters bouncing up and down. So I took (2) 21 inch zip ties and put those around the filter neck and the radiator support. Very subtle and discreet. You even have to look real good to be able to see the filters through the grill which I like.
And yes,I would a tune by the end of this year. I have to finish the last section of my Frankenstein exhaust which will be some sort of y back. Z1 sells a y back so perhaps I’ll go with them. That’ll probably be the extent of “performance” parts as I plan on buying a long block and build something real nice.
Old Feb 9, 2024 | 11:43 AM
  #73
Martinez1041
thank you. Will definitely look into it. $30 a sock isn’t bad and is cheaper then water getting in there
Old Feb 9, 2024 | 11:44 AM
  #74
filter sock.
Right, that's the terminology I was missing. Filter socks.
Old Feb 9, 2024 | 11:46 AM
  #75
camopaint0707
naw, i like it.
