Project Practicality
Old Sep 21, 2016 | 03:50 PM
  #31
Not bad, you gave this poor man some ideas
Old Sep 23, 2016 | 12:17 PM
  #32
p0on's Avatar
p0on
Love your setup with the Nismo Z rims.
Are you running square fronts? Any spacers?
More photos of the fitment please?
How does the driving balance change when going from staggered OEM -> square?
Looking good and keep up the good work!
Old Sep 23, 2016 | 02:31 PM
  #33
Dembflyr's Avatar
Dembflyr
These are square. Four nismo front wheels 9.5x19 +40. Tires are 255/40/19. No spacers the fitment is perfect in my opinion. Here are a couple of crappy pics.
I noticed zero difference going square. I doubt many people would. There's such a small stagger originally anyway.
Old Sep 23, 2016 | 03:52 PM
  #34
That fit is just about as perfect as you could get IMO, wheels right at the fender edge w/ a nice tuck for the tires, now THAT is Practicality done right!
Old Sep 23, 2016 | 07:33 PM
  #35
Dembflyr's Avatar
Dembflyr
I agree.
Old Sep 26, 2016 | 01:07 PM
  #36
Dembflyr's Avatar
Dembflyr
Getting ready for winter.
Got the coupe wheels wrapped in some Michelin X ice winter tires.
Also cleaned, clay bar'd and waxed them up.
Lookin spanky.
Old Sep 26, 2016 | 01:21 PM
  #37
Very nice. I do that, too, with my winter wheels, and have been meaning to get to them soon. You beat me to it! Although truth be told, the inner lip of my duckfeet look like pooh.
I'm needing two new rear snows, and have also decided on X-Ice this time around.
Old Sep 26, 2016 | 01:29 PM
  #38
Dembflyr's Avatar
Dembflyr
The reviews between the X ice and the Blizakk's were so close. The tipping point for me was the 40,000 mile tread wear warranty.
Old Sep 26, 2016 | 01:56 PM
  #39
Do you use spacers on those Coupe 18"s after the drop? I put 15mm adapters on for winter... third year coming up. Which is something else to clean pre-season.
If you do use spacer adapters, I strongly recommend buying some half-height spline-drive lug nuts, instead of using the little brass lugnuts that come with the typical set. The brass nuts tend to strip soon as you look at them.
Old Sep 26, 2016 | 02:01 PM
  #40
Dembflyr's Avatar
Dembflyr
Yup. I use 20mm and I already bought 20 new lug nuts for them.
Although I just used some open ended acorn lug nuts.
Old Oct 25, 2016 | 10:08 AM
  #41
Dembflyr's Avatar
Dembflyr
Ok, just one more thing before winter...
Maybe two.
Old Oct 26, 2016 | 12:58 PM
  #42
Dembflyr's Avatar
Dembflyr
I installed the Cusco bar today.
I had to paint the brackets copper.
Also removed the headliner so it doesn't rub. I am thinking about adding an aftermarket liner but I'm not set on it at the moment.
If I only had a good camera these might look better.
I have the vinyl to black out the window trim. Just need to find the time to do it.
Old Oct 27, 2016 | 07:01 PM
  #43
Dembflyr's Avatar
Dembflyr
I found some time today to black out the trim.
I followed Blnewt's DIY. It was a huge help.
And I still need a real camera.
Old Oct 27, 2016 | 09:24 PM
  #44
Really coming together with perfection, that copper bracket paint & the trim wrap turned out excellent.
Old Oct 29, 2016 | 09:32 PM
  #45
Dembflyr's Avatar
Dembflyr
I played around with my cheap iPad app again. I'm trying to decide what to do with my front grill down the road so I'm trying out some things.
