ToXIc's 6MT A54 Sedan
Old Jun 4, 2017 | 08:24 PM
  #256
Originally Posted by ToXIc
there should also be a disc of fiber (kinda like pillow stuffing) between the rubber boot and leather.
OEM? I don't have any fiber disc.
Old Jun 4, 2017 | 10:55 PM
  #257
4doorfury's Avatar
4doorfury
For sound deadening use gtmat pro off eBay. Been using it for a while makes a good difference and is priced well. I did the entire back seat area including the wall like in this thread as well as the front driver and passenger floor. Now when I drive all I hear is wind noise from the window area which can't be fixed. Super quiet
Old Jun 4, 2017 | 10:58 PM
  #258
ToXIc's Avatar
ToXIc
yea looking the pic you should see something white in there will get a proper pic for you, you have a 2011 also dont see why you wouldnt have any.
thought about it.. i need to
Old Jun 4, 2017 | 11:37 PM
  #259
ZahyMatar's Avatar
ZahyMatar
also after waiting for forever i finally upgraded my dashcam
What all did you purchase for your dash cam setup? I want to do it right the first time.
Old Jun 4, 2017 | 11:47 PM
  #260
ToXIc's Avatar
ToXIc
got it from massdrop.. it took frigging forever. it was around 300 BlackVue DR650S-2CH
Old Jun 4, 2017 | 11:59 PM
  #261
ToXIc's Avatar
ToXIc
hey guys is there a 12v ignition source in the trunk? hoping to find one in there before i go running one.
Old Jun 5, 2017 | 06:57 AM
  #262
Daddy Fat Sacs's Avatar
Daddy Fat Sacs
Yes there is for the tails, but I unfortunately do not know which wire is what. Check the FSM
Index of /FSM/G37
Old Jun 5, 2017 | 09:23 AM
  #263
ToXIc's Avatar
ToXIc
Seriously? What is different about it?
And all you covered was the backrest section?
yea definitely makes a good difference. before it resonated front that big plate.. all that is gone.. when i scrap the back to tap some wires i'll probably add some more.
Index of /FSM/G37
really? that sounds better than taping the amp.
Old Jun 5, 2017 | 10:46 AM
  #264
Having blown the 2017 budget on gears and tires, I needed an affordable project for later this summer. I think Dynamat on the backseat will be a fine project. And some sound/vibration deadening around the shifter, too.
Thanks, ToXIc. Always cool to find something new to add to the list.
Old Jun 6, 2017 | 10:30 PM
  #265
ToXIc's Avatar
ToXIc
recap here's where i left off with working on the air setup last year
now connected some lines ,harnesses and pressure sensors along with painting the board.
all i have left is bend new hard lines out of copper and drop the car off the get everything installed.
Old Jun 12, 2017 | 11:03 AM
  #266
ToXIc's Avatar
ToXIc
did a lil more with the air prep
and of course a project isnt truly complete until you offer the car gods some blood
Old Jun 12, 2017 | 11:12 AM
  #267
You ditched your clock for the airbag gauge? I think that's brilliant!
Good job with the blood, ToXIc.
Old Jun 12, 2017 | 11:17 AM
  #268
ToXIc's Avatar
ToXIc
thanks damn clocks are useless, a forum member Chris did the retrofit for me.
Had a fresh blade in the utility knife and my blood was hot from changing my dads stairs from carpet to hardwood so when i cut it started poring like water had to zip tie it shut so it could clot.
Old Jun 12, 2017 | 12:02 PM
  #269
Goonz's Avatar
Goonz
I have this dash cam as well, but just the 1-channel. Below is a link with great info on hard wiring that I used as a reference and contributed some helpful info.
https://www.myg37.com/forums/audio-v...-dash-cam.html
Old Jun 12, 2017 | 09:21 PM
  #270
ToXIc's Avatar
ToXIc
got in my proclip base today and Velcro mounted the Accuair touchpad.
it came out really nice, sturdy and easily in reach.
