New build: GTM TT Stg-II • '08 Infiniti G37 5-spd auto • The Shop CT
Old Dec 30, 2010 | 10:17 PM
  #61
SharpByCoop's Avatar
SharpByCoop
This was provided by GTM as the upgraded kit for the 5-speed. The 7-speed uses a different method?
The kit was mfg'd by 'Trans-Go'. May have been developed with the GTM guys, I dunno.
Coop
Old Jan 1, 2011 | 04:01 PM
  #62
Sam@GTM's Avatar
Sam@GTM
Great job coop, It looks like the guys at the shop have a great handle on the project .
Keep up the good work
Sam
Old Jan 1, 2011 | 04:16 PM
  #63
sunten1's Avatar
sunten1
Wow I got to come see this build looks great!
Old Jan 4, 2011 | 10:31 PM
  #64
SharpByCoop
We've been busy since the last post, but had a long holiday weekend. These things take time, even with no snags. Hector has barely had any other project on his lift and he's about 85% done.
We ordered a set of colder plugs from Sam yesterday and had him ship them next day. They are special plugs, as you know. He's got to put them in before final upper pipes.
I drove to the local Nissan dealership and picked up 14 qts. of 'Matic-S'. Sam recommended nothing but.
Jimmy asked me if I was excited and jumpy, as I'm stopping by often.
Actually, no. I'm more concerned with correct assembly than going for the initial rides. I'll have years to savor that. I am doing what I can (as errand boy and P/T tech) to help this forward.
Next day: Still in-progress.
Plugs arrived from CA to CT by 10am. Auto trans is back in, and I provided some flex hose for the BOV recirc tubes.
Here's some shots:
Both oil and trans coolers installed behind the Intercooler. Nice and tidy.
Here is a shot of the spacers provided for extra clearance for.... something.
Here's the oil junction black and relocated oil filter.
I ordered a set of the CAT 'test pipes'. Sam thought I already had them, and I thought they were in the package. A slight delay, but they will be here on friday. Thankfully GTM has them in stock!
Onward.
Coop
Old Jan 5, 2011 | 01:18 PM
  #65
christian655321's Avatar
christian655321
Keep an eye on that oil filter collar, I would use a sealant on the threads for all the attachments \du-hickys - Mine was leaking after a few months and had to be resealed.
Old Jan 5, 2011 | 02:31 PM
  #66
DmfG37sTT's Avatar
DmfG37sTT
Keep it up. Cant wait to see final build
Old Jan 5, 2011 | 02:34 PM
  #67
christian655321
since you are getting the test pipes how come you decided to go with the 2.5" ? Wouldnt the 3" down pipe and matching exhaust been ideal?
Old Jan 5, 2011 | 03:44 PM
  #68
dal1307's Avatar
dal1307
That cardboard template is a sweet idea. I will definitely be using that in the future and for more than just automotive related projects.
Old Jan 5, 2011 | 04:38 PM
  #69
SharpByCoop
Not for me. I wanted it quieter than louder and 600whp isn't in my future.
Sam suggested these and I agreed.
Coop
Old Jan 5, 2011 | 05:14 PM
  #70
akuma_83's Avatar
akuma_83
Love your build, cant wait for the finish product ! Subscribed !
Old Jan 10, 2011 | 02:18 PM
  #71
CDONNS's Avatar
CDONNS
Any updates!?!
Old Jan 11, 2011 | 02:24 PM
  #72
SharpByCoop
Some delays. Sam was Johnny-on-the-spot in sending out the test pipes w/resonators ASAP. They arrived last Friday. Thank you!
Once there they fitted them up, and the fitment had them sitting up against the floorboards, and 1/2" behind the cat-back flange. Sam advised us to remove the spacers under the engine and trans, but no luck. Still too close up, and too far back
Upon review, Jimmy, Hector, and I looked and decided that if we simply applied some heat and curved the 'S' bend downward from the engine side flange curve, it would solve both problems.
That said, the supply of oxy/acetylene was out, and first chance for replenish is probably today. Everyone took a pause and went on with other tasks.
These things happen.
Hector installed a Blitz boost controller, and will install an AEM AFR gauge low on the LH pillar.
Still waiting for my tuner (John Visconti) to get the ECU data to Sam.
Anyway, it's nothing but icy roads up here now, and with 15" of now due this evening. I'm in no big rush....
I'll update when that exhaust is correct. Thanks.
Coop
Old Jan 13, 2011 | 04:10 PM
  #73
Coprolite's Avatar
Coprolite
Riveting stuff. I can't wait to see how it turns out.
Old Jan 13, 2011 | 05:38 PM
  #74
Mike's Avatar
Mike
Will the zipties be able to handle the temperature of the oil lines or will they be secured later via something a bit more secure?
Old Jan 13, 2011 | 06:42 PM
  #75
DmfG37sTT's Avatar
DmfG37sTT
Those oil lines would have to get pretty hot to do anything to the zipties.
Ill google the temp that plastic melts at lol.
This was taken from answer.com
PVC, polyvinyl chloride, melts at 212 ฐC (about 414 ฐF). Teflonฎ, which we use to coat cookware, is polytetrafluoroethene - PTFE, and it melts at 327 ฐC (about 621 ฐF).
<!-- google_ad_section_end -->
Read more: Answers.com - At what temperature does plastic melt
