ModBargains.com | Your Official Source for Cusco | Best Deals!
Old Apr 10, 2012 | 08:49 PM
ModBargains.com's Avatar
ModBargains.com
ModBargains.com has been one of Cusco's premiere dealers for BMW enthusiasts and now we are excited to bring the same great parts and customer service for G35 community. Cusco, as most of you know already, is one of Japan's top tier suspension tuner companies and their products are nothing but top notch. We are steadily bringing in inventory from Cusco Japan to keep in stock so we can better help service our customers. In fact, Yuki from Cusco delivered our first batch of inventory:
Coming in May 22nd Container to ModBargains:
288 540 A/ 288 540 CA---G37 Coupe/Sedan Front Strutbar---30 kits
288 492 FS---G37 Coupe/Sedan Front Power Brace---5 kits
288 492 R---G37 Coupe/Sedan Rear Power Brace---5 kits
288 492 RB---G37 Coupe Rear Bulk Power Brace---5 kits
252 311 A28---G37 Coupe Front Sway Bar---5 kits
288 311 B25---G37 Coupe Rear Sway Bar---5 kits
Give me a call directly at 714 582 3330 ext 8003 to place your order or just ask for Frank! Don't see a Cusco product that you are looking for? Just ask!
Cusco Type OS Front Strutbar:
This Cusco Strut Brace for the G37/350Z eliminates the chassis flex you get when cornering. Your G37/350Z does not come with a strut brace stock, so when your are corning the shock towers will flex up or down. This Cusco strut brace drastically reduces this flex, adding rigidity to your G37/350Z, improving cornering and steering response. The Cusco G37/350Z Strut Brace is purely bolt-on and can be installed using minimal tools.
•Improved handling & chassis rigidity
•Improved steering response
•Bolt-on installation
Cusco Front Camber A-Arms
When you lower your 350Zthe wheels will tend to camber outwards, creating uneven wear on your wheel bearings and tires. Leading to costly repairs and tire replacements in the future. These Cusco Front Camber A-Arms will fix this problem by extending the reach compared to the OEM A-Arms and reversing the negative camber.
•Direct drop in replacement for the stock OEM arms
•Allows you to adjust your camber angle
•Allows you to change your vehicles handling characteristics
•Includes a special rubber compound bushing to minimize noise
•Allows approximately 1 - 1.25 degrees of adjustment
•Recommended for lowered vehicles to improve handling and tire life
Cusco Adjustable Toe Control Rods
Your stock toe arms are not adjustable and so your toe can never be adjusted for optimum handling performance after suspension modifications have been made. These Cusco Adjustable Toe Control Rods offer a great range of adjustability. Featuring an adjustment from +10mm to -10mm, which will allow the driver to properly adjust the toe angle for any setup. Each toe rod have integrated dust boot to keep dust and unwanted contaminants away from the spherical end.
•Allows approximately +10mm to -10mm adjustment
•Includes a Lock nut to ensure tight and permanent fitment
•Integrated dust boot for increased life
•High quality spherical end (NMB)
Cusco Adjustable Rear Trailing Rods
Your stock Rear Trailing Rods are not adjustable and so your toe can never be adjusted for optimum handling performance after suspension modifications have been made. These Cusco Adjustable Rear Trailing Rods offer a great range of adjustability. Featuring an adjustment from +10mm to -10mm, this will allow the driver to properly adjust the toe angle for any setup. Each toe rod have integrated dust boot to keep dust and unwanted contaminants away from the spherical end.
Cusco Front/Rear Swaybars
Your stock swaybars are very effective for normal everyday driving. However if you are an aggressive driver or like to track your car, your stock swaybars will not cut it. They allow far too much body roll and flex for a firm feel when cornering. These Cusco swaybars dramatically decrease body roll and leaves you with a stiff steering feel. Depending on the position of the bar, oversteer and understeer can be modified for enhanced vehicle control. All of Cusco's swaybars are painted in Cusco's signature blue and are direct bolt-on with all the necessary hardware included. Get rid of body roll and that mushy feeling in the corners with these Authentic Cusco Swaybars.
•Signature Cusco Blue Finish
•Reducing body roll during hard cornering
•All the necessary hardware included
Update:
Just picked up more inventory from Cusco!
NEW ITEMS
Cusco Front Power Brace:
Cusco Rear Bulk Power Brace:
Cusco Rear Power Brace:
-Frank
Old Apr 11, 2012 | 09:16 PM
Fresh Mobile's Avatar
Fresh Mobile
cusco strut bar for '08 G37s coupe shipped to 11429?
Old Apr 11, 2012 | 10:05 PM
AvosG37's Avatar
AvosG37
PM me cusco strut bar G37s coupe shipped to 91352
Old Apr 11, 2012 | 10:18 PM
Rad_Slinger's Avatar
Rad_Slinger
please pm me availability of the front strut bar and best price.
vehicle is in my sig.
thank you.
Old Apr 14, 2012 | 03:31 PM
twerk's Avatar
twerk
price to 22030 for custco front strut bar for a g37xs sedan pls.
Old Apr 14, 2012 | 03:35 PM
xeddyboi420x's Avatar
xeddyboi420x
price installed at modbargains please!
Old Apr 14, 2012 | 04:11 PM
SoFresHSoCleaN's Avatar
SoFresHSoCleaN
Price quote on the cusco sways for a '10 G37 sedan shipped to 33615? Thanks
Old Apr 14, 2012 | 07:03 PM
Nomad4g63's Avatar
Nomad4g63
Front strut bar for G37 sedan to 33175
Old Apr 17, 2012 | 04:42 PM
ModBargains.com
PM sent! G37 Strutbars are all sold out now - they went by quick! Next stocking inventory is arriving early May. I have a pre-order list going on for the strutbars - spots are filling up quick!
-Frank
Old Apr 18, 2012 | 02:31 AM
Sena's Avatar
Sena
cusco front strut bar shipped to 98230 please.
Old Apr 18, 2012 | 08:36 PM
ModBargains.com
You got PM!
-Frank
Old Apr 26, 2012 | 11:25 AM
ModBargains.com
Updated first post with G37 specific Cusco Parts coming in-stock very soon! Many of the items are almost all pre-sold, so please call 714 582 3330 ext 8003 for availability!
-Frank
Old Apr 27, 2012 | 06:56 PM
ModBargains.com
PMs replied!
-Frank
Old Apr 30, 2012 | 03:11 PM
Zack342's Avatar
Zack342
Can I get a price on a G37 6mt sedan FSTB shipped to 02368 please?
Old Apr 30, 2012 | 03:29 PM
BosMaSwaG37's Avatar
BosMaSwaG37
Frank, PM priced shipped to 22030. Thanks. Also include ETA
