Special DBA 4000 & 5000 Series Sport Rotors
Old May 25, 2011 | 01:39 PM
  #46
JEBperformance's Avatar
JEBperformance
DBA 4000 Series, 5000 Series. The best rotors compared to any brand. From company that specializes only Disk Brake Australia.
Old May 25, 2011 | 01:40 PM
  #47
JEBperformance
Thermal Stability Profiling
4000 and 5000 series brake rotors can handle extreme applications thanks to Thermal Stability Profiling or TSP.
This unique process provides greater thermal stability than standard street discs. TSP enhances the micro structure of the disc rotor for performance applications.
Greater thermal stability allows your discs to take more heat, making them more stable under heavy braking for longer. TSP also means improved brake pad and disc rotor life, and delayed brake fade.
DBA’s Kangaroo Paw
delivers significantly improved braking performance under all conditions to make you safer than ever before.
The innovative Kangaroo Paw design runs cooler, is stronger, and outperforms traditional straight vane disc brake rotors.
So what makes it work so well? To answer this, let’s look at a car’s braking system. This system is critical in terms of vehicle safety and performance. Being able to stop reliably, time after time, under heavy braking conditions can mean life or death.
Every time the brakes are used massive pressure is built up through the braking system. The force your foot applies at the brake pedal is multiplied many times at the disc rotors, creating friction and extreme heat.
The extreme heat can cause disc rotors to warp, distort and in some cases fail. Traditionally, heat is removed as air flows through the rotor passing between straight ‘cooling vanes’. However, the straight vane design does not provide the ideal conditions for heat to be dissipated and tends to allow an unwanted ballooning effect.
Kangaroo Paw disc rotors will quickly remove the heat, cool the discs, and return to optimal operating temperatures ready for the next braking application – without this ballooning.
The Kangaroo Paw features 144 precisely positioned diamond and tear-drop pillars. The pillars create greater strength, reliability, and a more efficient cooling system. Greater surface area means more rapid heat dissipation.
Cool air flows in from the centre of the disc, while hot air is forced to the outside of the disc - regardless of rotational direction. The pillars provide greater strength across the disc rotor and reduce the tendency for disc distortion.
More efficient cooling improves brake pad and disc rotor life, and helps reduce brake fade.
That’s why the Kangaroo Paw system is so effective.
Available across a range of products for most popular vehicles, it’s the greatest advance in brake rotor design for decades – guaranteed!
The 5000 series rotors are designed for the serious street driver. These 2-piece ultra-high performance rotors feature aerospace grade materials (
Alumalite) for added thermal (heat) protection to your vehicle's wheel bearings, by providing greater resistance to distorion as it allows the disc to expand uniformly.
For the serious driver, the 5000 series 2-piece ultra-high performance rotors feature aerospace grade materials for added thermal (heat) protection to your vehicle's wheel bearings.
The Alumalite centre / hat / bell is made from light-weight 6061-T6 aircraft aluminum material (re-usable).
The aircraft-grade aluminum centre
provides greater resistance to distortion as it allows the disc to expand uniformly.
The 5000 series rotors also feature NAS (National Aerospace Standard) bolts and lock nuts.
<iframe title="YouTube video player" src="http://www.youtube.com/embed/8PzWFn6lGBs?rel=0" allowfullscreen="" width="425" frameborder="0" height="349"></iframe>
4000 and 5000 series rotors also incorporate DBA's Thermo-Graphic heat paint marking which change colour at specific temperature thresholds.
By monitoring the markings, drivers can check their braking performance quickly and easily.
Disk Brake Australia Rotors are sold separate. Either left or right rotors.
2008+ G37 Sport DBA 4000 Series Slotted Rotor
42314SL Front Left MSRP $350
42314SR Front Right MSRP $350
42315SL Rear Left MSRP $245
42315SR Rear Right MSRP $245
2008+ G37 Sport DBA 4000 Series Drilled & Slotted Rotor
42314XS Front MSRP $371 (must order 2 for front left and right)
42315XS Rear MSRP $266 (must order 2 for front left and right)
2008+ G37 Sport DBA 5000 Series two piece Rotors
52314BLKSL Slotted Front Left Rotor MSRP $504
52314BLKSR Slotted front Right Rotor MSRP $504
52314BLKXS Front Drilled/Slotted Rotor MSRP $504 (must order 2 for front left and right)
Thank you for ordering MADE IN AUSTRALIA DBA Rotors from JEB Performance.
Old Jun 3, 2011 | 05:19 PM
  #48
JEBperformance
Call us toll free @ 866-445-0935 to place your order over the phone with greater discount. International customer please call us @ 213-985-3446.
Old Jun 15, 2011 | 12:36 PM
  #49
JEBperformance
DBA 4000 & 5000 Series Sport Rotors Thermal stability profile
Old Jul 4, 2011 | 01:26 PM
  #50
harbin9er's Avatar
harbin9er
Hi, what are the weights of the DBA 4000 series front and rear rotors, and the DBA 5000 series 2pc front rotors?
thanks
Old Jul 13, 2011 | 02:48 PM
  #51
JEBperformance
thanks
Front weight is 30 lbs
Rear weight is 25 lbs
thank you
Old Jul 26, 2011 | 06:00 PM
  #52
JEBperformance
5000 series weighs 5 lbs less than 4000 series DBA rotors. Total of 20 lbs less burden on your wheels.
Old Jul 27, 2011 | 05:00 PM
  #53
JEBperformance
5 Lbs = 10 extra horses to your rear wheels.
Old Jul 28, 2011 | 06:25 PM
  #54
JEBperformance
Cheaper than OEM out lasts OEM looks much nicer than OEM
Old Jul 29, 2011 | 06:29 PM
  #55
JEBperformance
DBA weekend special, anyone who sends PM between mid night July 30, 2011 to mid night July 31, 2011 will get PM back with very very good price.
Old Aug 1, 2011 | 03:49 PM
  #56
JEBperformance
Thank you for all your PM inquiries over the weekend. All PM replied.
Old Aug 2, 2011 | 05:26 PM
  #57
JEBperformance
We will extend our weekend offer until end of August 2011.
Old Aug 3, 2011 | 03:04 PM
  #58
JEBperformance
Today I want to share with you regarding special insurance under your existing vehicle insurance policy. Some of you may already know, our vehicle insurance will not cover aftermarket parts we purchased on our vehicle. Further some aftermarket parts will even void our warranty. So we are left with making repairs out of our own pocket.
Now there is an option with most insurance underwriters to purchase separate "Special Parts Insurance". Added to your premium will insure all your aftermarket mods so you can have piece of mind.
Also some cases if you have special insurance added to your premium. Lets say you had an accident and your bumper needs to get replaced. Instead of ordering OEM bumper, now you have option to order aftermarket body kit you have been eying on.
If you want to know more please PM me. I can also give you a price quote on insurance with special parts added to your policy. For less than what you are paying. Or call your broker to find out more useful information.
Old Aug 3, 2011 | 07:39 PM
  #59
JEBperformance
New LOWER Price, we just receive OK from DBA for lowest price ever. Can't post price. But PM us and find out new lower price for 4000 & 5000 DBA rotors.
Old Aug 4, 2011 | 03:38 PM
  #60
JEBperformance
YES special promotion still on going, order yours at any time during month of August 2011.
