Special DBA 4000 & 5000 Series Sport Rotors
Old Aug 5, 2011 | 05:30 PM
  #61
JEBperformance's Avatar
JEBperformance
All cars have weaknesses by far our OEM rotors are not built to standards. Seems to be the first to cause major problem. DBA out lasts, out performs, and costs even less than OEM rotors.
Old Aug 5, 2011 | 05:31 PM
  #62
JEBperformance
Thermal Stability Profiling
4000 and 5000 series brake rotors can handle extreme applications thanks to Thermal Stability Profiling or TSP.
This unique process provides greater thermal stability than standard street discs. TSP enhances the micro structure of the disc rotor for performance applications.
Greater thermal stability allows your discs to take more heat, making them more stable under heavy braking for longer. TSP also means improved brake pad and disc rotor life, and delayed brake fade.
DBA’s Kangaroo Paw
delivers significantly improved braking performance under all conditions to make you safer than ever before.
The innovative Kangaroo Paw design runs cooler, is stronger, and outperforms traditional straight vane disc brake rotors.
So what makes it work so well? To answer this, let’s look at a car’s braking system. This system is critical in terms of vehicle safety and performance. Being able to stop reliably, time after time, under heavy braking conditions can mean life or death.
Every time the brakes are used massive pressure is built up through the braking system. The force your foot applies at the brake pedal is multiplied many times at the disc rotors, creating friction and extreme heat.
The extreme heat can cause disc rotors to warp, distort and in some cases fail. Traditionally, heat is removed as air flows through the rotor passing between straight ‘cooling vanes’. However, the straight vane design does not provide the ideal conditions for heat to be dissipated and tends to allow an unwanted ballooning effect.
Kangaroo Paw disc rotors will quickly remove the heat, cool the discs, and return to optimal operating temperatures ready for the next braking application – without this ballooning.
The Kangaroo Paw features 144 precisely positioned diamond and tear-drop pillars. The pillars create greater strength, reliability, and a more efficient cooling system. Greater surface area means more rapid heat dissipation.
Cool air flows in from the centre of the disc, while hot air is forced to the outside of the disc - regardless of rotational direction. The pillars provide greater strength across the disc rotor and reduce the tendency for disc distortion.
More efficient cooling improves brake pad and disc rotor life, and helps reduce brake fade.
That’s why the Kangaroo Paw system is so effective.
Available across a range of products for most popular vehicles, it’s the greatest advance in brake rotor design for decades – guaranteed!
The 5000 series rotors are designed for the serious street driver. These 2-piece ultra-high performance rotors feature aerospace grade materials (
Alumalite) for added thermal (heat) protection to your vehicle's wheel bearings, by providing greater resistance to distorion as it allows the disc to expand uniformly.
For the serious driver, the 5000 series 2-piece ultra-high performance rotors feature aerospace grade materials for added thermal (heat) protection to your vehicle's wheel bearings.
The Alumalite centre / hat / bell is made from light-weight 6061-T6 aircraft aluminum material (re-usable).
The aircraft-grade aluminum centre
provides greater resistance to distortion as it allows the disc to expand uniformly.
The 5000 series rotors also feature NAS (National Aerospace Standard) bolts and lock nuts.
<iframe title="YouTube video player" src="http://www.youtube.com/embed/8PzWFn6lGBs?rel=0" allowfullscreen="" width="425" frameborder="0" height="349"></iframe>
4000 and 5000 series rotors also incorporate DBA's Thermo-Graphic heat paint marking which change colour at specific temperature thresholds.
By monitoring the markings, drivers can check their braking performance quickly and easily.
Disk Brake Australia Rotors are sold separate. Either left or right rotors.
2008+ G37 Sport DBA 4000 Series Slotted Rotor
42314SL Front Left MSRP $350
42314SR Front Right MSRP $350
42315SL Rear Left MSRP $245
42315SR Rear Right MSRP $245
2008+ G37 Sport DBA 4000 Series Drilled & Slotted Rotor
42314XS Front MSRP $371 (must order 2 for front left and right)
42315XS Rear MSRP $266 (must order 2 for front left and right)
2008+ G37 Sport DBA 5000 Series two piece Rotors
52314BLKSL Slotted Front Left Rotor MSRP $504
52314BLKSR Slotted front Right Rotor MSRP $504
52314BLKXS Front Drilled/Slotted Rotor MSRP $504 (must order 2 for front left and right)
Thank you for ordering MADE IN AUSTRALIA DBA Rotors from JEB Performance.
Old Aug 8, 2011 | 06:18 PM
  #63
JEBperformance
Old Aug 9, 2011 | 02:20 PM
  #64
JEBperformance
Bump for DBA's Kangaroo Paw rotor system
Old Aug 10, 2011 | 03:20 PM
  #65
JEBperformance
Bump for drills on DBA rotors. For dissipating heat from all your hard braking.
Old Aug 11, 2011 | 12:11 PM
  #66
Viper62382's Avatar
Viper62382
PM new price on dba 5000 series for g37 sport to 75043
Old Aug 11, 2011 | 02:46 PM
  #67
JEBperformance
PM sent
Old Aug 12, 2011 | 03:44 PM
  #68
JEBperformance
<table style="width:auto;"><tbody><tr><td></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From August 12, 2011</td></tr></tbody></table>
  #69
JEBperformance
<table style="width:auto;"><tr><td><a href="https://picasaweb.google.com/lh/photo/YSGefuus-8nMOngpRPiUfw?feat=embedwebsite"><img src="https://lh6.googleusercontent.com/-1mSCfxegEtw/TkWCCMUgEBI/AAAAAAAAACo/yCIA2_rQjZw/s800/trackskill_testimonial.jpg" height="800" width="571" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="https://picasaweb.google.com/104924078085030371609/August122011?authuser=0&feat=embedwebsite">August 12, 2011</a></td></tr></table>
Old Aug 12, 2011 | 07:00 PM
  #70
JEBperformance
BUMP for the weekend
Old Aug 15, 2011 | 06:32 PM
  #71
JEBperformance
DBA best application for G37 Sport touring cars
Old Aug 17, 2011 | 02:26 PM
  #72
JEBperformance
DBA racing spec Brake Rotors. Preferred among racers.
Old Aug 19, 2011 | 01:03 PM
  #73
JEBperformance
Finally Friday. Have a nice weekend.
Old Aug 22, 2011 | 12:52 AM
  #74
Kuro's Avatar
Kuro
Please give me price for DBA 5000 front drilled/slotted and DBA 4000 rear drilled/slotted shipped to 33406, my car is 2008 G37S coupe
Old Aug 22, 2011 | 08:47 AM
  #75
JEBperformance
PM sent
